The problem has to be in the damper control inside the refrigerator section. Disconnect the refrigerator from power and remove the food from the top shelf. The damper control is in the box near the top of the refrigerator section behind the temperature control knob. Remove the knob and cover until you can access the damper control. You can prop the damper control open with a pencil or something to make the refrigerator work until you get a part if you need to. Here is the part you need.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
