Your Honda would be a four stroke engine, so your fuel would be straight gas, you will notice on the base of the engine there is a location to put oil, a 4 stroke engine is lubricated by the oil in the base of the crankcase. On a two-stroke engine.oil fuel mixture lubricates the crank so it has no provision to add oil to the engine.
Testimonial: "Thanks donegeli! That's what I thought, I just wanted to make sure.(With my husband passing, I am having to figure out all sorts of wonderful things:)"
Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
