Vacuums Logo
Posted on Feb 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A 40 W fluorescent lamp gives out more light than a 4o W filament bulb.explain whether the fluorescent lamp is actually using electrical energy at the same rate as the filament bulb??
Anonymous
Level 3:
  • Master 927 Answers
  • Posted on Feb 19, 2011
Anonymous
Master
Level 3:
Answers
927
Questions
0
Helped
335686
Points
2827
The lamps are both using 40 watts of energy, but the fluorescent lamp gives more lumens (visible light measurement) than the incandescent.
Fluorescent gives at least 5000 lumens for 100 watts.
Incandescent gives 1750 lumens for 100 watts.
You can see that if you had a 100 watt incandescent, it would be 1750 and you would only need 35 watts of flourescent.
Gary
Need the manual
All domestic appliances have a rating plate which informs you of the voltage, wattage and energy rating. Its the wattage that will give you a rough theoretical idea of the power but in reality it only applies to the power consumption of the item not its actual sucking/pick-up rate.
Oct 17, 2014 • Vacuums
I cant get the wand out
TRY TURNING LEFT AND THEN RIGHT ,TRY W D 4O OIL
Fitting a light and the wiring is not coloour colded, so which one goes to the L and which colour goes to the N.
light bulb sockets are not colour coded as it does not matter which way round live and neutral are connected. earth will go to the outer case of the bulb holder (if applicable).
if you are not sure, i must recommend that ask a qualified electrician to actually install the light, as mains electricity can be dangerous, and incorrect installation can carry risk of electric shock or fire.
please think carefully before doing any electrical work yourself if you are not confident in your abilities.
Jun 18, 2011 • Vacuums
I've never had to change a CFL bulb like the GE 35972 in my kitchen ceiling fixture. It looks like a squared off pretzel with the socket in the middle and facing up to the ceiling. It's been in there for...
CFL bulbs are held in place by a friction fit, but it is a very tight fit. Grasp the CFL by the sqaure plastic base and pull firmly away from the socket. You may have to wiggle it a little, but don't try to pull it out by the globe because they are very fragile and break easily. I would imagine the pins would be interchangeable with some other model, depending on the number of tubes and the number of pins. Just take your bulb with you to compare. If you have any specialty electrical supply houses in your town, that would be a great place to look. I'm giving you a link where you can order them if all else fails, but CFLs have become pretty common, so you shouldn't have too much trouble finding one.
http://www.e-conolight.com/lamps/lamps-compact-fluorescent.html
May 01, 2011 • GE Vacuums
3helpful
My silent ionic breeze GP just stopped working (no blue light, no static). only a couple of years old. cleaned weekly. how do I obtain someone to possibly fix it as trouble finding replacement?
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=0&ProductId=473&gclid=CKWj6N--u6cCFYjsKgodLxrBBQ
Airpurifierrepair will fix your unit but it starts at 159.00 flate fee.
Here are some other things to try first:
Dirty Collection Grid.
  • In case of a problem with your Ionic Breeze air purifier, the first thing you should do is clean the collection grid. According to the Ionic Air Breeze instruction manual, the most common problem with the units is that the collection grid gets too dirty and the unit no longer effectively cleans the air. Removing the collection grid from the top of the unit, then wiping it down with a damp sponge or rag, as well as turning the entire unit upside down several times to dump out any dirt from inside the housing, will help restore the unit to maximum operating efficiency.
Glowing Blue
  • Another common problem with the Ionic Breeze unit is that it no longer glows blue, which it is supposed to do when operating in germicidal protection mode. If the unit is no longer glowing, it is likely that the UV fluorescent bulb inside the unit has died or has decreased in output. The bulbs are meant to last for about a year, and touching the bulbs or getting them in contact with oil or dirt will shorten their lifespan. Try replacing the light bulb before assuming there is a more serious problem with your Ionic Breeze air freshening unit.
Transformer or Circuitry Issues
  • Other problems that may occur with the Ionic Breeze that you will need to troubleshoot and repair include transformer or circuitry problems. If the transformer goes bad, the unit will not work at all, and will have no power when you attempt to turn it on. Similar problems can occur if the circuit board is defective. Because of the danger of electrical shock or damage, it is best if you have a repair facility work on your Ionic Breeze unit if you suspect transformer or circuitry problems
Mar 06, 2011 • Vacuums
Light bulb burning out.
My guess is you didnt get the correct value lamp for your application. Sears doesnt have the proper lamp for your machine - of you didnt want to get it from them?
Try again at Sears or RepairClinic.com for the proper lamp.
I hope this helps you
a
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
