If you forgot your BIOS password. see this... http://www.wikihow.com/Break-a-BIOS-Password
If you forgot your windows Account Login password, the following page is a good description of your choices... http://pcsupport.about.com/od/tipstricks/tp/find-lost-windows-passwords.htm
Also, check out... http://ophcrack.sourceforge.net/
If the above does not work, and you have important files that you don't want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. At least you may not lose you files.
Good luck
Forgot Windows password?
Of course, you canuse Windows Password Unlocker to create a password reset disk with a CD/DVD orUSB flash drive. But what you do firstly is to find an accessible PC with a driverand a writable CD/DVD or USB drive. Then you can follow the steps below to burna password reset CD or USB flash drive.
Step 1: Download WindowsPassword Unlocker
Step 2: Install theprogram and open it.
Step 3: Burn apassword reset disk with CD/DVD or USB drive
Step 4: Reset lost passwordwith the burned CD/DVD or USB drive
Note: There are 3versions of Windows Password Unlocker. Just select one of the version suits youbest.
It is very easy andit takes you less than 5 minutes. Good luck!
For the Windows password you will need to reformat your hard drive. If that would not be done or if there is another way of removing the password without removing and reinstalling the operating system or of using your laptop by working around, windows password does not make sense at all. Hope this helps. Thank you.
safe mode will open windows with minimal amount of drivers, but will still require a password. Safe mode with command prompt will open in a simulated dos mode, and you can type "explorer" at the command prompt to open the gui and get to the start menu. buty this may not help.
i have sucessfully removed administrator password from windows by taking the hard drive out and installing it in another system as a secondary hard drive. i then manually deleted the "sam" file from windows/system32.
you can also reset the password by reinstalling windows or performing a second, parallel, installaation of windows (identical OS) on the same drive, and then deleting the second installation.
1: Use any efile manager like SELEQ 1.65 2: Open SELEQ 1.65 and go to Root C: 3: Options and FIND, write MMCSTORE press OK 4: Send this file by Bluetooth or Infraread to your PC 5: Rename the file MMCSTORE to MMCSTORE.TXT 6: Open the file and the password off the MMC are there
