When loading my laptop it's taking at least 20 minutes to start the internet. The laptop is only 2 years old and it has only recently started to do this.
You could try removing items from startup. Start > Run > type MSConfig > Startup. Uncheck items you don't want to load. This will make your PC faster. This can also be done with CC Cleaner if you haven't done so already.
Hi.
the first thing i would check is to make sure there is no dirt or dust stopping the fan from running because if the fan is not running it will heat up and shut down or if the fan is running slow it will shut down.
and for running slow i would do a good clean up get rid off stuff thats not needed anymore.like music,pictures,the more your harddrive has on it the longer it will take to load and run.
Hi keneddy,
Always wait a few minutes to see if your bread machine start to mix after a few minutes. If the oven chamber is cold it will gently warm up a few minutes before it starts to knead/mix. This can sometimes take anywhere from 4-5 minutes and longer. If it doesn't start kneading after about 20 minutes then you do have a problem. Whole wheat programs often warm up before any kneading begins. All you will hear is a faint clicking noise while the heat comes on.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
have you deleted history , cookies , temporary internet pages? also when is the last time you defraged the computer?
also you can try : right click on c:/ in my computer and click properties then disk clean up and it will calculate , when the next window pops up it will show you the description of files to delete and you can click on the more options tab to also remove old restore points or windows components ( not recomended )
let me know if that works or if we need to see if you have a virus that is causing problems
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Its not worth having it looked at. $100.00 for a new 400.00 unit? My unit is doing the same thing. Turn it on and 2 to 5 minutes later it may come on. Change to video 3 4 5 etc it stop again. Only works with a cold start. Something in the unit has failed and is heat related. My original Kenwood 20/20 recevier still works. Must be 40 years old. New products just last 5 to ten years max if your lucky.
It's a HP Compaq
