SOURCE: Qx5 is not responding
the microscope may be trying to draw too much current from your USB ports, your computer will disable the device if it does this. When this happens one of the easiest (and cheapest) solutions is to acquire a Powered USB Hub (with it's own Plug top power supply). This should aleviate any extraneous current draw to the Power supply.
SOURCE: Cant get the microscope lights to come on
I have the same microscope, I ordered the actual disk from digital blue, was like 5 bux plus shipping, flee bay has em for 10 bux, the down loaded ones off internet are just drivers so your pc only can see
the device.
SOURCE: QX5 Problem with Windows Vista
Do not plug the QX5 in until the software is installed.
I got mine to work on Vista 32bit. Insert the cd, cancel autorun, view files on the cd. locate setup.exe, right-click on the setup and go to properties; then compatibility; then put a check in "run this program in compatibility mode for windows xp" AND put a check mark in "run this program as an administrator; the click Apply and click OK.
Right-click on the setup.exe again, this time choose, Run as Administrator.
Install away from the default. My recommendation is c:\users\(your user name\digitalblue.
Plug in the QX5, then go to Start, Programs, Digital Blue, click on QX5
SOURCE: i have lost my
Here are the links to the available downloads from Digital
Blue: QX5/Smithsonian Computer Microscope Drivers for WIN
ME, 2000, XP, Vista 32-Bit QX5
V2 Computer Microscope Drivers for Windows Vista 64-Bit Download for
Windows Vista 64-Bit QX5
V2 Computer Microscope Drivers for Windows 7 QX3,
QX5 V1, QX5 V2 Computer Microscope for Mac OSX 10.4-10.6 QX5
Computer Microscope V1 Video Codecs for 32 bit versions of Vista/Windows 7
SOURCE: 109 error message when running
According to the Digital Blue website, there are a variety of things that can cause this error, including
USB configuration issues, QX5 connectivity problems, or an improperly
installed device. To troubleshoot, try the following steps. If one does
not work, try the next until the problem is resolved.
1. Exit from the application, unplug the QX5 from your
computer, and restart your computer. Once your computer has rebooted,
plug in the microscope and restart the application.
2. If you are using a USB hub (an external device that allows
you to connect additional USB products to your computer), exit the
application and plug the microscope directly into the USB port on your
computer. If the microscope works when plugged directly into your
computer, there may be a problem with your hub, or it may not be
supplying enough power to run the microscope. If your hub does not have a
power adapter, you will need to plug the QX5 into your computer's USB
port or use a hub that is powered.
3. If you are not using a USB hub, try different USB ports.
Always exit the application, unplug the QX5, and then plug into a new
USB port. Wait at least one full minute to make certain that Windows
recognizes the QX5. Then start the application again. If you are still
experiencing the problem, try another USB device (if possible). If no
USB devices are working, there is a chance your USB ports are not
working properly and you should contact your computer manufacturer to
resolve the problem.
4. If you have a laptop, make sure the laptop is using its
power adapter. When running on battery, some laptop computers don't
supply enough power to USB ports and as a result the QX5 will not work
properly.
Note: The following steps require some experience with Windows
computers. If you are comfortable modifying advanced settings on your
computer (like the Device Manager or BIOS), proceed at your own risk.
Otherwise, respond to this email and provide your phone number so a
member of our technical support team can assist you.
5. Plug in the QX5. Go to Start > Settings > Control
Panel and double click on the System icon. For each of the following
items (if present), select that item, then click the Remove button:
After removing all the devices, click the Refresh button.
6. Try lowering the hardware acceleration of your video
adapter. To do this, follow the steps below that apply to your operating
system:
If using Windows 98, Windows 98 Second Edition, or Windows Me:
If using Windows 2000 or Windows XP (classic view):
If using Windows XP (XP style category view):
...'fix continued'
While in the Performance tab, move the slider for Graphics Hardware
acceleration one notch to the left. After you do this, the panel should
indicate "basic accelerator function". Click OK, then click OK again to
exit from the Display Properties window. Restart your computer and
launch the QX5 software. If this does not fix the problem, repeat the
process until all the available HW acceleration settings have been
tried. (Different video adapters disable the acceleration at different
points on the slider.)
7. Unplug your QX5 microscope and restart your computer in
"Safe Mode." To get into "Safe Mode," you must reboot your computer and
press the appropriate key before the Windows logo screen appears. If you
do not know how to do this refer to your computer's manual or contact
your computer manufacturer.
If you are successful in starting in Safe Mode, there will be a
"Safe Mode" logo in each corner of your desktop. Then follow these
steps:
a. Click Start/Settings/Control Panel.
b. Double-click the System icon.
c. Go to the Device Manager tab.
d. For each of the following items (if present), highlight the item, then click the Remove button:
e. Close the device manager, and restart your computer
f. Go to Start/Settings/Control Panel and double click the Add New Hardware icon.
Go through the Add New Hardware Wizard. When the Wizard asks if you want Windows to search for new hardware, select "Yes".
Note: You may be asked to insert your Windows CD or the CD that came
with the microscope. If you are prompted to insert one of these CDs, you
MUST do so or the microscope will not be properly installed. (Contact
your computer manufacturer if you cannot find your Windows CD.)
g. When the new hardware installation is complete, restart your system, then try running the QX5 software again.
8. Uninstall the QX5 software (which will not delete any video or
images you may have captured as long as you re-install to the same
directory) by following these steps:
a. From the start menu, open the QX5 program group and select the uninstaller.
b. Follow the instructions to uninstall.
c. Restart your computer.
d. Insert your QX5 CD-ROM and follow the install instructions.
e. Plug in your QX5, wait a minute for Windows to recognize and install.
f. Start the application.
Blue:
QX5
Download for
QX5
QX3,
QX5
Blue:
QX5
Download for
QX5
QX3,
QX5
downloads from Digital Blue:
Drivers for WIN ME, 2000, XP, Vista 32-Bit
Download Drivers
QX5
Download for Windows Vista 64-Bit
QX5 V2 Computer Microscope Drivers
for Windows 7
Download Windows 7 32-Bit
Download Windows 7 64-Bit
QX3,
QX5
Download Codecs
Downloads and install the appropriate driver software from Digital Blue:
Download Drivers
QX5 V2 Computer Microscope Drivers for Windows Vista
64-Bit
QX5 V2 Computer Microscope Drivers for Windows 7
QX3, QX5 V1, QX5 V2 Computer Microscope for Mac OSX 10.4-10.6
Digital Blue:
Download Drivers
64-Bit
Digital Blue:
Download Drivers
64-Bit
The Quick Start Guide can be downloaded here:
Digital Blue:
Download Drivers
64-Bit
Digital Blue:
Download Drivers
64-Bit
