It is a guess, but wireless doorbells have adjustable frequencies so that your neighbors door bell button doesn't ring yours as well. My guess is that the bell push and the chime unit are mis-matched. Do you have a manual? I can't find one.
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
need more info. Doorbells do not need 2 xfrms. The red off 24 volt xfmr foes to door switch and returns on white. If you have 2 door switch one switch to front door label on doorbell and the 2nd goes to back door label. What is the brand and model number/ I'll try and walk you thru it.
It appears that you and your neighbor's wireless door bell are on the same radio frequency. You or your neighbor will need to change their base station (were the sound come out of) unit. If you or your neighbor still have their Owner's Manual you can find out how to do it in the Trouble Shooting Section. If that's not available, remove the cover, if necessary and you will find a small panel board with a series of movable slid switches (they are very small) . Moving those to a different position will change the frequency. The inside of the back cover should have instructions on how to reprogram it. DESA International bankrupted over a year ago, but some manuals in a pdf format are still available on line. Try http://www.desatech.com/ as there may be an Owners Manual that's still available. Different divisions of DESA International were sold off to other companies during the bankruptcy, so you may be led to another site. Good luck.
It would appear that there are pins in both the ringer and door button and you have to change them so they match. To remove the door button, slide the case straight up slightly (maybe 1/8 inch). Pry the top of the case away from its base and slide down to remove the entire button assembly. The pins are inside, next to the battery. 5/6/7 seems to be the default, so any other combination of three pins should solve your neighborhood conflict. (Don't use pin 8. That one changes the ring from a two-tone chime to a 16-note sequence.)
in the chime box and remote you can change the setting for the remote signal that is picked up( refer to your manual for the correct settings) these will be a set of pin connections in the chime box and in the remote switch that will have to be set to another selection
