This uses an 8 hour timer which means it goes into defrost every 8 hours shutting down the compressor and fan motor.
So, are you saying that this will run (compressor and evaporator fan) for 8 hours at a time?
Also, shouldn't the evaporator coils have an even layer of frost covering them completely?
No as the temperature gets satisfied it will cycle off.
If not and unit continiously runs without reaching temperature, you have a refrigerant leak.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
