Amtrol ST-5-C THERM-X-TROL ASME Expansion Tank, 2 Gallon  Logo
Posted on Feb 11, 2011
New, 1 year, boiler unit makes loud banging noises (in pipes) throughout house all night long. What could be the cause? Thanks, Cathy
craig
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 45 Answers
  • Posted on Apr 20, 2013
craig
Contributor
Level 1:
New Friend:
Cheetah:
Answers
45
Questions
0
Helped
15997
Points
62
Air in system bleed air at all radiators
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Glow worm 45-60 standing boiler making banging noises when in operation
The noise you refer to is called Kettling, it is caused by the hot water in your boiler not being able to leave the boiler quick enough, if the problem developed quickly and your system is a "fully pumped " system this would generally point to your pump either has failed or is on its way out, i.e . your radiators would not heat up as the hot water is stuck in the boiler hence the banging......( if you know where the pump is you can generally feel if it is running by a small vibration ) if you have gravity hot water and pumped heating circuit then I would assume that it is noisy when just doing HW, and the banging is a problem that has gradually got worse it can indicate that the boiler is scaling up (are you in a hard water area). if this is correct there are various additives that can be put in the system to help quieten it down, I suggest you really need a heating engineer to diagnose fully.
Bosch gwh 425 hno-l
CHECK LIST
- is the BTU'S enough for the space
- is there proper flow through boiler
- should have 20'F-30'F difference between inlet and outlet temp
- is there air in the system
- is there a lock on via controls that is set to lock out under 20'F
- no matter what if boiler is working properly it should be able to maintain 20-30'F temp difference from inlet to outlet
ex. 60'F in, 85'F out = 25'F split boiler is working right, if temps do not rise means house insulation my be so bad BTUS calculated for the coldest conditions was to low
Loud noise filling water
Probably heat trap nipples, or other constriction in pipes.
http://waterheatertimer.org/New-water-heater-making-noise.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment and say what you find
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Noisy water pipes when neighbours use water
Install air chamber to cushion sudden-stop of flowing water.
Water flow coming to sudden stop is called water hammer, and will bang pipes, but also loosen plumbing joints, causing leaks.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#bang
http://waterheatertimer.org/images/Flow-rates-water-hammer-600.jpg
Air chamber has to be vertical, and about 18" long, with cap on top.
By code each Hot and Cold line at each tap will have air chamber located behind the wall. So there are two air chambers at each tap.
In your case, you can probably add air chamber to your Hot and Cold lines and solve problem for both dwellings.
Water hammer is caused because water does not compress like air.
So when long column of water suddenly stops... the whole pipe-full of water comes to sudden halt... and that water could weigh 1-1/2 pounds ... and just like a hammer head moving, the weight of water bangs the pipes to dissipate energy, causing noise.
When i turn on the hot water tap the boiler starts to bang and rattle. doesnt do it with just the central heating on. please help
first check for loose pipes the you might want to add a damper on the pipe to absorb the hammering just t in a piece of pipe and make it go higher than the pipe with the noise and put a cap on topp of that
1helpful
Boiler bangs when hot tap turned on
Hello,You need to install a domestic/high pressure extrol/expansion tank on your cold water pipe.Should slove noise.
2answers
My old Aquastar tankless natural gas water heater used 1/2" gas line. My new Bosch 2700ES -NG says it requires no less than 3/4" inside diameter gas line. Do I have to replace all the gas supply lines...
None !!
3/4 pipe from gas meter or regulator. At low pressure there may not be enough gas flow through a smaller pipe for the boiler when on full bore.
The boiler input pipe will be 1/2" needing a reduction from 3/4 so there is some leeway.
I have about 8' of 1/2 pipe on mine [Bosch Worcester] from the reg. and it is ok.
You could use the existing 1/2 and try. No harm done if insufficient-just replace. If you have some other gas takeoff on the same line a 3/4 pipe up to that take off is most likely.
Smell of oil throughout the house when the boiler is on
Other than the stench of fuel oil permeating every soft surface throughout the house, there are numerous health hazards associated with exposure to petrochemical vapors. Shut the unit off until you can get it repaired.
Top Amtrol Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an Amtrol Water Heater Expert? Answer questions, earn points and help others
