SOURCE: lg tromm
The bearing is pressed in in the factory and is only available as a rear tub assembly. They claim to have extremely tight tolerances to prevent wear and unbalance. Check your owner's manual there may be an extended warranty on the rear half of the tub.
SOURCE: bad bearings on front loading lg washer 1832cw
Sorry, but you are not so lucky. LG should not even offer those parts, as it takes special hydraulic presses to install some of that. For anyone but the manufacturer them self you must replace the back half of the outer drum (I believe it is a 3045ER0008C in your case) which contains the installed seal and bearing, plus I'd recommend replacing the spider asm 4434ER0002A, as the shaft may be a bit worn where it contacted the seal and bearing, and you don't really want to go through all that work (at least 2 hours) only to have to do it again. A FixYa rating would be appreciated. Thanks.
SOURCE: LG Tromm washer WM2688HWM tE error code. Very easy
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
SOURCE: machine (LG wm1280 7kg)works fine except drum wont roatae
You can repair it, but it really needs to be done by a qualified technician. What has very possibly happened, is the spider assembly has snapped that connects to the drum (that's the noise you heard).. The drum has now collapsed. Different machines open differently. The later ones have plastic outer frames, and when the "spider arm"collapses, it eats large chunks out of the drum internally. It in my opinion is not then worth the repair. For the older ones, one needs to remove drive belt and pulley then strip front of machine to enable you to open it up. This will let you then remove the inner drum. Inspect spider assy. and see if actually broken. (I'm sure it is.) Phone agents for replacement parts which will be 2 bearings and a seal and the spider assembly.Install and reassemble.
SOURCE: VERY LOUD GRINDING NOISE LG WM-2277HW Front Load Washer
Get a new washer. Perhaps another brand.
The fix for me was to get a new washer. Had same issue with loud spin cycle. Tried researching while wife was continuing use of washer. Then the LE message appeared.
Took back apart and found that water had leaked and caused a boat load of damage. Bearings shot, seal leaks, drum leaks, Stator damaged. Same issue as 'jammy64' stated.
Cost to repair wasn't worth it. Going to get an
Electrolux model.
