You don't say what it's blinking (code F11 or FdL?) The problem may be communications between the CCU circuit board and the MCU circuit board. The problem is most likely with the CCU circuit board (inside, top, back, plastic case) There are bad solder connections where the relays (5 of them) and the spade connectors are supposed to be firmly connected to the circuit board. Humidity or vibration will often make and break the communication circuit, many times stranding the machine during the cycle. The repair is to remove the CCU case then remove the circuit board and touch-up those solder joints I mentioned. If you're not up on soldering techniques you could remove the CCU case with the circuit board and take them, along with this response, to a good appliance repair shop and they should be able to help you out. Good luck.
No water filling the washer or the pressure switch is not activating.Check your screens in your water valve for dirt. Make sure the washer is not siphoning water out of the tub as it is filling.
