Install a new OS for your Toshiba Satellite A205-S4617 Notebook.
Download a utility programme called asc-setup from IObit.com THis is a freeware utility that will repair your registry errors and much more if you purchase the whole system.
When you have run it go to toshiba.com and download the latest drivers.
That will sort your problems out for you.
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Copy only valid files to the card and do a scan before it is replaced. Now replace the card and battery and switch on the phone. If the phone hangs up or is slow when it is switched ON , then it is confirmed that the software has errors and will need a reinstallation.
Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Thank You for using Fixya
