HI
If you want to turn it off, the is a switch on the bottom left side in the middle. If you want to do something else you need to clairfy what you want.
Not sure why your removing the battery? If you are shuting down the machine. Close all running programs before shuting down otherwise the machine has to close each program in turn before thr machine can shut down all together. Depending on how the settings are for the power button. The shut down process can be forced by holding down the power button until the machine has shut down. Black screen instead of white. Hope this helps answer your question. Regards Bob from OZ
The machine shut down usually when ther is a problem with the load to the grup moter.This is usually a board problem.You can check if the machine shut down when the grup is trying to move.
Chances are the treadmill started by shutting off in the middle of a workout and has gradually gotten to the point that it will not run long, or turn on at all, in some cases. This is most likely caused from a worn deck and belt. If the belt and deck is not routinely waxed, it wears down and causes friction. This friction builds up heat which can fry your electronics. The machines circuit breaker shuts the machine down to protect the major electronic components. This protective measure, built in by the manufacturer, will only help for so long. After a few times of shutting down due to the heat, it actually does damage to the electronics. The result and correction usually ends up being a new deck, a new running belt, and in most cases that have gone on too long, the motor control board. I am attaching a link for the service manual for further information. Parts for Matrix T3 Treadmills T3x T3xi Belts Rollers Decks SPORTSMITH...
to shut down press and hold the start button until the machine shuts down, can take up to 10 seconds for the machine to shut down. If this does not work remove the power lead and drop the battery out of the system. You access the battery from underneath - there will be a slider you need to push to eject the battery.
Machine shuts down after 6 seconds...
Answer
Failed: retry
DVD/VCR Combo was working fine then one day machine started
shutting down after a few seconds of...
(More)(More)
shutting down after a few seconds of operation. It happens with both, a
VCR and a DVD. I can watch 6 secs. of a movie at a time.
The issue seems to be with the power settings of your machine. Go to control panel and then go to power options. There you can change the and settings fro auto shut down of your machine.
Hope this works. If this does not solve your issue, please do write to us. We will be pleased to solve your issue.
