Normally washers sit on the floor and are drained, by a 'bent pipe', either into their own waste pipe or into a shared sink system. The higher the waste pipe is the harder the drain pump has to work to push the water out. Normally this should not be a problem as the pump should be powerful enough for the task!
So- the answer really is that it is not the washer height which matters but the waste height- and even then not much!
Hope this answers your question.
Cheers,
John C
