Re: Samsung Refridgerator side by side stopped cooling
I have a Samsung RS21DCNS side by side and today the temprature started to increase to room temp. I have turned the fridge off and on and it has colled slightly but not enough. Can you help
I have exactly the same problem. Everything appears to be working but the fridge is maintaining room tempreture. Tried all that I know to cure. I have exactly the same problem. Everything appears to be working but the fridge is maintaining room tempreture. Tried all that I know to cure.
My refridgerator also appears to stop cooling for a few days previous I could hear a fan whirring inside which would stop immediately when i opened the door but yesterday the temperature light began to flash and the fridge does not appear to be working at all?My refridgerator also appears to stop cooling for a few days previous I could hear a fan whirring inside which would stop immediately when i opened the door but yesterday the temperature light began to flash and the fridge does not appear to be working at all?
You can't post conmments that contain an email address.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
0845 726 7864 samsung know of this problem and are doing free fixes to all of them just phone the number it doesnt matter about the warranty as they have extended them all free to 5 yrs.
There are numerous problems including noisy fan that stops when doors open to no water and all are free to fix.
This is caused by the ice building up in at the back - the fan catches the ice and eventually will stop. With the fan malfunctioning the temperature will rise and the light then flashes. Keep searching the web, and you will find instructions how to remove the back and de-ice it. I had exactly the same problem 2 months ago. Make sure that it is fully de-iced, including the tray at the bottom. Ours has worked OK since!
Sounds like thatyou refrigerator has leaked out the refrigerant. If you have a condenser i.e. cage on the back , place your hand over it and see if it is warm if it is not then if deffinaltey the gas.
this is not a diy job and you will need an engineer with relevant qualifications..
Dear friend,
ngfam at you service! happy to assist!
You can download the user manual at lg online and or order one there!
It gives you specific instructions and diagrams how to install the
water line!
HERE IS THE SITE TO GET THE MANUAL FOR LG
http://www.samsung.com/us/consumer/type/type.do?group=homeappliances&type=refrigerators
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
as a rule of thumb mfgs say give the unit 24 hrs to stablize where are you gettings the readings the fridge or freezer sides freezer readings run from -8 to -10 the fridge should run 34to38
