What make/model is the treadmill? What speed does this behavior occur? Does the walking belt slip, while the motor and rollers continue to turn? If the walking belt is slipping then the motor belt needs to be tightened. If the walking belt slows with your weight on it, does this happen at 1-3 mph and still occur at 4-5 mph? It could be your body weight causing it to slowdown, try to increase the speed to 4 or 5 and see if it still happens. If so, is the treadmill rated for your body weight? Please be more specific.
This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the
belt or when the treadmill operates normally for a given period of time
with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time
Test every step.
http://www.youtube.com/watch?v=38w4PkiWIBY&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
