Phil n ted tubes sadly are not covered by warranty my pram had all 4 tires do it including the new ones they said there was a batched of shonky tubes and sent me new ones as i kicked up a stink as it was only a few months old, but it did it again when we had a heat wave :( why not try buying a new tube and tire from a bike store the ones phil n ted supply are dodgy! and deflating it and puting the tire back on the rim wont work cos they tube seems to just buldge again when walking and pope the tire off and come off the rim. hope this helps its a well knowen problem that phil n ted couldnt be bothered fixing.
bought new tyres but they would bulge again so found a simple diy solution: get some rubber (broad rubber washers from the plumbing section), cut a piece to the size that it covers the very centre of the area where the tyre bulges - position the tyre properly on the wheel again and gently pump it up - just make sure it is well pumped up as we are used to do with ordinary bicycle tyres.
Bought new tyres but they would bulge again so found a simple diy solution: get some rubber (broad rubber washers from the plumbing section), cut a piece to the size that it covers the very centre of the area where the tyre bulges - position the tyre properly on the wheel again and gently pump it up - just make sure it is well pumped up as we are used to do with ordinary bicycle tyres.
hi does it seem to be the tyre or the inner platic rim, also which country are you in?
