Sony PlayStation 2 (PS2) Console Logo
Anonymous Posted on Feb 07, 2011
I cant find the installation code for need for speed may i know what is the code?
William Dehn
Level 3:
  • Master 318 Answers
  • Posted on Feb 07, 2011
William Dehn
Master
Level 3:
Answers
318
Questions
0
Helped
112807
Points
1021
8249-7EE3-84EW-TXGT Hope this helps...please rate this high.
  • William Dehn
    William Dehn Feb 07, 2011
    ZQG8-UQXD-NEZ5-LE8D-JM6T
    Try this if it doesn't work
  • William Dehn
    Some more if they don't work.
    DPQY-KFG5-GBQ9-9T27-QQGD | TWSA-5699-LZVM-KQS2-F9EL | QEFP-MA2W-MNL8-DKES-KY2C | 3WBB-HGFK-4CCH-C5MD-XEXW
My suzuki swift 4WD 2007 model speedometer not working DTC error code p 1777
double posted?
replace the speed sensor.
the SM covers all this, ever seen a service manual.
is this a USA car,?
you posted to USA forum. so...
DTC errors are based on
engine and trans in your car, called the Drive line
we cant guess that ever. why work on car not knowing whats there>? how can you buy parts or read correct chapter in the service manual lacking this 1 key fact.?
the speed is dead most times with VSS dead.
replace VSS , clean it or fix its busted up wires.
swift or swift +
we only have 2007 in canada no USA< so why not say country first
why must we beg?
2004 to 2011 in canada, sorry cant do outside N.America, sorry.
ill look up the canada codes, is speedo in KPH?>?>>?>>>
swift non + ended 2001 here.
oops my source of books has no canada swift books.
answer:
the VSS can only be in 2 spots.
under hood, (there is one other exception)
1: on the axle near (pinion ring gear), to measure speed.
2: on some cars the ABS wheel sensors.
In case 2 , the ABS knows speed and simply tells the PCM speeds at all times and in turn PCM sends speed data to the CLuster.
are all fuses good.?
Hi :D Please help me with my problem in Need For Speed Undercover Installation, My CD is not Original, When I Installed it I Entered the Registration Code that I have found in the Internet and when the...
You used pirated software which is ******* and installed a game that needs a key to operate and now that the server for the game knows that you are using a pirated version and fake key, you want support? Sorry you need to buy the game.
2answers
I cant restore myphone tw1.....coz needed ang password which is i dont know the password is
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 16, 2012 • Cell Phones
Cant install adobe flash latest version on my dell inspiron E1705
Ur computer is to old and can't take the new software up grade.Used the old software as already in the computer or must replaced the computer.Because now ur old computer CPU clock not meet the software codes speed to read the programimg logics codes.
2001 DODGE NEON COMP CODE NEED TRANS SENSOR REPLACE IT STILL SAME CODE CAR RUNS PERFECT 3 SPEED AUTO NO OD CANT CLEAR LIGHT CAR WAS IN ACCIDENT WAS HIT NEAR COMP LOOKS LIKE IT TOOK A VERY SMALL INPACT ALL...
If the scanner won't reset the codeand disconnecting the Negative battery terminal doesn't rest the code the computer is damaged and you will need to find another used one that will work in the vehicle or contact the dealer for a new one and get it programmed. Even used these are expensive and hard to find. Having had to replace one myself once I know the cost involved and how difficult it is to find a good used one.
259helpful
8answers
Cant enter a cheat code for Need for Speed Underground 2 -
you can find the cheat codes at the site
www.consolecheatcodes.com
STARVIEW CODES FOR THE 18TH DECEMBER DUBLIN IRELAND I HAVE THEM BUT CANT INSTALL THEM PZ PLZ PLZZ PLZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ I NEED HELP AS TO HOW TO INSTALL THEM
All you need to know is here
http://www.freewebs.com/keycentre/
Using the new codes below,
00 Code - B0 B8 4F 04 E6 5F 87 80
01 Code - A3 EB EC 07 D6 49 D2 EB
Worked a treat for me earlier today.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
