SOURCE: Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
SOURCE: Freezer door handle loose
u could always set the handle in place where it needs to be and use caulk or super glue to go around the handle and that should help it stay in place if that doesnt work the website www.amana.com to see if it has warranty for the broken handle good luck
SOURCE: Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used:
HANDLE, DOOR (WHT)
Level of difficulty:
Difficult
Time to do repair:
30 - 60 mins
SOURCE: I have an Amana Model#ABB2522FEW but don't have a
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%2012828152.pdf
