To be able to Disable the touchpad you need to press FN + F6 to disable it you can enable it by pressing the same keys. Some Helpful Keys that you need to know about Lenovo.
FN + F5 - Enable/Disable Wireless
FN + Esc - Enable/ Disable Webcam
Don't Forget to say Thanks. Thanks for using Fixya.
Testimonial: "Thanks for the fix, working fine! thanks again."
Yes there a solution by pressing the fn+F9. or you can go to your device manager to disable it.
SOURCE: lenovo G550 touchpad scroll bar does not work with
I had this same problem. This is how I solved it:
1. Install the touch-pad driver from Lenovo's website, but remember which folder it installed into
2. Go into the device manager, it's located in the control panel, and click on mice and other pointing devices, then on the mouse device
3. In the mouse device window, go to drivers, then update driver, then say locate manually, then find the folder you installed the drivers to
4. Restart and try the scroll wheel
SOURCE: how to change touchpad settings for lenovo g550, I
You really can't do much with settings for a touchpad. I would recommend disabling it and using a wireless mouse. var fctb_tool=null; function FCTB_Init_c6f64f985d3644929e3995eea1c55206(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_d35d1f3861484992b99b0e9345d90151(t) { fctb_tool=t; start(fctb_tool); }
