SOURCE: HI there, I have a
If you can, plug the memory card into your computer, open it for viewing and delete all files on the card. Then put it in the phone and format it. This is the only way I can think to do it. At least this is what I had to do. Good Luck.
SOURCE: Memory Full/Format disk
it needs to format it to allow it to read by the camera...a sort of hand shake..so format it and go shooting
SOURCE: my 4gb microSd sandisk is infected and cannot be
It supposes to have a tiny lock/switch on the side. Move it up or down to turn off/on the write protection.
SOURCE: I purchased a 4GB Sandisk
your samsung Gravity 2 wont read the HC format, there is not much you can do sorry. the SD HC is a newer format for devices in the last year or so. Older devices will not accept the HC format cards. I did the same thing! And im in the business, easy mistake. Keep it around though you'll use it soon, just not in your Samsung. Gurvy
Testimonial: "thank you, I realize this was the case... in my opinion, the SD/HC card manufacturers should put a warning on the packaging. I did get my money back. "
Transcend produces different kinds of memory modules, including Random Access Memory, or RAM, chips for computer systems, USB flash drives and a variety of flash memory card formats, such as SD.
Transcend's flash memory devices are usually preformatted with either FAT32 or NTFS. Macintosh systems primarily use the HFS+ file system format.
You can format a Transcend flash memory card to the FAT format using the Disk Utility program on a Macintosh.
Insert the Transcend flash card into a card reader connected to the Mac.
Some Macintosh computers have SD card readers built in.
Open the Disk Utility program in the Utilities folder.
Click the flash card in the left column of the window.
Click the "Erase" tab.
Click "MS-DOS (FAT)" in the "Format" drop-down list.
Enter a name for the flash card in the "Name" box.
Click "Erase" to format the flash memory card to FAT.
Hope this helps
