SOURCE: Canon PIXMA mp240 All-in-one InkJet Printer. Error code: 2,140,2
I had exactly the same problem (error Code:2,140,2) in Canon PIXMA MP250, and it was solved when I replaced both ink cartridges which were almost empty (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
SOURCE: my printer canon pixma mp258
Indicator appears blinking lights on the printer " P,O, 8′. That Mean The print head temperature above the specified value. You can replace the ink cartridge or refill the cartridge. Step to resolv this error Step 1 : Turn Off Printer Step 2 : Remove Cartridge Step 3 : Refilling the cartridge Step 4 : Reinstall the cartridge Step 5 : Turn The printer ON If it still does not work you can use the following methods How To Reset MP 258 error 5200 Step 1 : The printer is off and plug the power cord. Step 2 : Press the button STOP / RESET and hold, then press and hold the POWER button Step 3 : POWER button still press, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed. Step 4 : Release both buttons simultaneously Step 5 : The printer will proceed in a while (a while), then the LCD panel will show the number zero (0) Step 6 : Computer will detect NEW DEVICE, Ignore it... Step 7 : Press the power button, then the printer will turn off Step 8 : Press the power button again, then the printer will be ready to use
SOURCE: my canon mp258 show error code p08 ,,what to do
printer canon mp258 eror code 5200
or p08 warning in printer
SOURCE: Getting error on XP, using
http://support-sg.canon-asia.com/?personal
reinstall driver, download here
i hope this helpfull
thanks for using fixya
