Unplug High voltage lead from HV splitter. This is a red wire going from HV transformer to similar (white plastic) device located up front, between picture tubes. Disconnect the one which is coming in, by strong energetic pull down with pliers. Leave those which go to picture tubs in. Make sure that disconnected wire is far from other components or metal parts (high voltage - SEVERAL INCHES SPARK CAN OCCUR) Turn the unit on - if different than 3 blinks - the splitter is your problem.
Sorry I have not got back to you sooner. Thank you for the response. I will look thru the service guide and parts layout to locate the wire then try that. Hope it work's! I have also read about changing CP110 also if the green light problem continues, I think it is 220uf 200v which is gonna be kinda difficult to find, do think I should try that too?
