Question about Bosch Axxis WFL 2060 Front Load Washer
My washing machine motor won't work, changed the brushes and cleaned commutator as one brush has broken up in housing, causing a a short as smoke came out while on a spin, control pcb is clicking every 30seconds while i run a spin cycle so assuming its ok. How can i check the motor further, i.e is there a themal fuse or which terminals out of 6 on the the conn'r can I meter across to check for volts.Model is WFL12440gb/05, fd8502, 700959.The motor is 1200 spin held in with 2 bolts/screws with easy access brush change at the sides.many thanks.
6ya staff
SOURCE:
Anonymous
SOURCE: Bosch Maxx 6 WFL 2061 Front Loader W/M
brushes usually available on ebay,
if the drum rotates but does not spin, this could likely be brushes or component problem (i.e triac or relay) on control PCB. - the latter was the problem i had and this was easily spotted as a blackened track on the Relay on the pcb.
Brushes should be ~£5. - check the existing brushes first before buying them.
fitting is easy, BUT a word of warning..which you probably know anyway..
before meddling though in the machine, locate the large capacitor and with electical screwdriver and discharge all the terminals to earth first! - YOU MUST DO THIS TO AVOID ELECTRIC SHOCK!! - even if the machine is unplugged.
remove motor & undo the back plate to release old brushes.
clean of motor of any excess carbon dust, - this can eventually cause arching if not cleaned away.
reassemble and fit all plugs back.
THEN TAKE 5 MINUTES TO CHECK WHAT YOU HAVE DONE BEFORE SWITCHING ON. -
Do not rush anything - take your time.
Posted on Apr 26, 2008
Anonymous
  • 243 Answers
SOURCE: How to check and change brushes WFL2060
I do not have access to the literature for this exact model. But in my experience with this company the service panel is a large panel in the rear or side. If you can open the unit up the motor is the most distinguishable item in the washer. Then it should just be 3-4 wires and a matter of removing the 4 bolts that bolt it to the chassis. Then once you have the motor out if you know how to change the brushes it will be easy. If not you can always take it to a local electric motor shop that does motor rebuilds. Theres is about 3 locally to me that cost between $25-$70 a motor depending on the motor. but to do it yourself the brushes kit usually cost 15-30 dollars.
now if you wanted to check the motor you can always getting electric motor cleaner and spray the motor a little bit while its inside the unit. Then you can see when it runs if it still is laggy and has a burnt hot smell. If this occurs then you most likely need it to be rebuilt. It is not always the brushes that need changing sometimes the armature of the motor has warped which is causing excess wear on the commutator which makes it lose contact with the brushes. This can cause it to either wear through or make an excessive gap between the two.
oh and dont attempt to access it from the bottom this can cause damage to the unit and/or injury to self.
Hope this helped in some way if you need further assistance feel free to leave more info and i will be glad to assist you.
thanks,
Nate
Posted on Aug 22, 2008
Anonymous
  • 4 Answers
SOURCE: bosch washing machine
I just did this. Fitting the new brushes was fiddly but not impossible. Its easier if you remove the motor first as this makes access a lot easier.
Posted on Sep 05, 2008
Anonymous
SOURCE: changing the brushes when the motor is off
how do you remove the brushes on a Bosch Classixx 1200 washing machine?
Posted on Jul 10, 2009
Anonymous
  • 126 Answers
SOURCE: Bosch Axxis WFL 2060 Washer, not spinning.
IF THERE IS BLACK DUST UNDER THE MOTOR IT IS USUALL DEAD. YOU CAN REMOVE MOTOR FROM THE BACK I HAVE DON IT. YOU NEED A METER TO CHECK THE MOTOR. I CAN HELP.
Posted on Apr 25, 2010
Washing machine isn't spinning and making a loud humming noise . Could it be the brushes need replacing ?
If it is carrying out the wash cycle it still COULD be the brushes but it is difficult to say from a distance!
However it COULD be the control board not powering the motor on fast spin- a visual at the brushes and commutator should clarify.
Brushes
Now, a word or two of advice from a retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the commutator, often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
It's your choice though ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
Oct 09, 2011 | Washing Machines
Hoover ac120 , the washer will not get up to full spin speed, have just changed the carbon brushes on the motor, it does spin but struggles is there any other problem that could cause this?
Here is an extract from my guidance notes on no/poor spinning. The new brushes are probably not contacting the commutator properly, not without the commutator being skimmed ;-0(
It is not uncommon to find that the brushes are worn sufficiently for them to not make perfect contact with the commutator at the higher speeds- bouncing and sparking. Now, a word or two of advice from this retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the commutator (like the worn ones!), often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
The choice of course is entirely up to you- but do not forget that it is not an uncommon fault, especially if the washer is not exactly new. Others I have given this advice to have chosen new brushes and I don't blame them!
John C
Jul 23, 2011 | Hoover Washing Machines
My galley won't turn its drum. The pump is functioning, filling and emptying the unit normally but the motor won't turn, except for an occasional twitch. There is no hum or smell of burned...
It does sound as if the motor requires replacement because it is struggling. It is not uncommon to find that the brushes are worn sufficiently for them to not make perfect contact with the commutator at the higher speeds- bouncing and sparking. Now, a word or two of advice from this retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the commutator (like the worn ones!), often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
John C
Jul 22, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Are the brushes inside the motor or on the outside on my beko wm1510w washing machine. the drum has stop moving
The brushes are inside the motor and run on what is called the commutator located at one end of the motor shaft.
It could be that the motor requires replacement unless it is the control board not powering the motor.
Now, a word or two of advice from a retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the com, often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
John C
Jul 05, 2011 | Washing Machines
Hi Replaced moter brushes which were worn but still not working have noticed the ring that the brushes run on has a step showing ware. This would be the second set of brushes the machine has had and is...
What follows is my general advice on motors and brushes!
Good luck,
John C
Apr 09, 2011 | Washing Machines
My maytag washing machine is showing a fault indicator on the motor, it washes but stops when it trys to spin
It does sound as if the motor requires replacement because it is struggling, particularly when called upon to run the spin cycle. It is not uncommon to find that the brushes are worn sufficiently for them to not make perfect contact with the commutator at the higher speeds- bouncing and sparking. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the commutator (like the worn ones!), often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
Good luck,
John C
Apr 05, 2011 | Maytag Washing Machines
Intermittently trips mains fuse when kicking into fast spin
(Sorry but this does go on a bit!)
It does sound as if it is the motor causing the tripping especially if the washer is not very young.
It is not uncommon to find that the brushes are worn sufficiently for them to not make perfect contact with the commutator at the higher speeds asked of it in spinning- bouncing and sparking.
The carbon dust from the worn brushes can also cause 'shorting', in some cases cured by removing the motor and carefully cleaning/blowing off the carbon dust - which is well worth trying. If that does not cure the tripping it's possibly a new motor.
Good luck,
John C
Mar 30, 2011 | Hotpoint Washing Machines
Beko WMA 620 W washing machine takes forever to do a wash as it keeps pausing then the drum doesn't rotate when it reaches the spin cycle
It sounds as if the motor requires replacement because it is struggling, particularly when called upon to run the spin cycle. It is not uncommon to find that the brushes are worn sufficiently for them to not make perfect contact with the commutator at the higher speeds- bouncing and sparking. Now, a word or two of advice from this retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the commutator (like the worn ones!), often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
Good luck,
John C
Mar 23, 2011 | Washing Machines
How to exchenge the brushes
Hi from retired Englishman in SW France @ 16:04 Tues afternoon.
Sorry but you may not like this answer!
I strongly recommend changing the motor. If you manage to change the brushes in the motor they might last only a short while- maybe months- because they will not seat properly on the motor commutator- not unless a lot of skilled work is carried out on the commutator.
I know motors are expensive but this is my best solution.
Good luck
John C
Feb 01, 2011 | Washing Machines
Want to replace motor brushes...any tips on this
I need to also, so please post what you learn. I found several examples for other WMs on YouTube (search brushes carbon washing machine) Note, I was able to get my Bosch Axxis WFL 2060 spin working again with the following quick carbon dust cleaning trick:
1) Unplug WM and tip up to a 45 degree angle and then safely stabilize so you can safely access motor from bottom. No need to take off back or disconnect motor.
2) Using a small tool like a 1/4 allen wrench or medium screwdriver start tapping repeatedly (for 2 mins) on the brush holders, and back metal clips that connect to the brushes, your just moving the dust around really.
3) Next using an alcohol damp cloth clean the motor commutator - on this motor it is easily exposed on one of the sides 90 degrees away from, and in line with brush holders. Hold cloth on commutator and turn motor, this will also make it clear if commutator is damaged. You cloth should be pretty dirt after 2-3 rotations.
Repeat 2 and 3 above a few more times cleaning up all the carbon dust off the commutator and around the brushes.
After that tip down and test again. A more thorough cleaning could be done by removing brushes and cleaning em - but this will buy you a few weeks/months of operation.
Sep 28, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
136 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
