SOURCE: sony kds r60xbr1 tv
Power supply, and or a failure on one of the boards that is causing the supply to go in to protect mode, or both.
The set will require factory level service.
Jerry G.
SOURCE: blue haze/blue dots on hd tv
You likely have a bad optical block. Sony was supplying the optical block as a warranty repair until June of this year, but that warranty has expired.
SOURCE: Yellow Tint on Lower Right Side of Sony KDS-R60XBR1 TV Screen
Hi, Sony will repair your TV free of cost for yellow tint problem. Click Sony Support for details.
SOURCE: Motorola DCH3200 Cable Box
Be sure that you took the time to force the output of the DCH3200 to 1080i. They do not seem to come set that way by default! This is true whether you are using either the component or HDMI output.
Power OFF the unit and immediately push the Menu key on the front panel. Using the remote, be sure that the 2nd line of the config is set to 1080i and not something less.
