Is this your product, Back to Basics Smoothie Maker Elite, Part Number: SE2000B
http://www.everythingkitchens.com/back-to-basics-smoothie-SEC-Elite.html
This took awhile to find but you are looking for Gasket/seal U12-72.
It can be ordered here:
http://www.abtecparts.com/Back_to_Basics_blender_gaskets.htm
For a head gasket to seal properly, the head and engine deck surfaces must be clean, smooth and flat. Any foreign material such as dirt, carbon, old gasket material or abrasive residue on either surface may interfere with sealing by preventing firm contact between the mating surfaces and gasket. Debris can act like a bridge, and form pockets that create a path for leakage to occur.
Debris can also become embedded in the surface of the gasket and damage it. Debris may even damage the surface of the head and/or engine deck, which can lead to repeat head gasket failures unless the damage is diagnosed and repaired.
To avoid these kinds of problems, make sure the surface of both the head and block are perfectly clean before installing the head gasket. http://rubber-sales.com/rubber_beedings.html
