LG LSC26905 Side by Side Refrigerator Logo
Posted on May 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our LG side-by-side, model # LSC26905, suddenly stopped running when my wife was dispensing ice. The owner's manual and the gent at the customer service phone line were no help at all. This happened late Sunday afternoon, and we are waiting for the nearest authorized LG service repair outlet to open this morning. Breaker and outlet are fine. Does anyone who speaks English as a first language have an idea how to restart the refrigerator? Are one-year warranties standard on large appliances nowadays? Does anyone else find that outrageous?
mike cooper
Level 3:
  • Master 884 Answers
  • Posted on May 04, 2017
mike cooper
Master
Level 3:
Answers
884
Questions
Helped
404886
Points
1991
Switch off completely and leave for 30 seconds. switch back on and cooling should start in under 5 minutes. If not, check inline fuse and output to compressor.
5 Related Answers
A
Anonymous
  • Posted on Sep 15, 2007
SOURCE: LG Refrigerator water and ice dispenser stuck
We just had this problem and we fixed it by peeling off the soft rubber covering (the part you press the glass against)and then putting it back on. There is a plastic tab beneath that could get stuck if the rubber part gets an air pocket or bent out of shape. This took 2 minutes and worked like a charm.
Anonymous
  • 210 Answers
  • Posted on Jun 03, 2008
SOURCE: LG SXS Refrigerator LSC26905 ice maker
LG has a new ice cube tray to solve this problem.
Part number is 3390JA1150A
Sgt 48
Anonymous
  • 750 Answers
  • Posted on Oct 12, 2008
SOURCE: Regrigerator shows error code 1F
Hello tr-6
Welcome
You Wrote,
LFX25960ST LG FRENCH DOOR REFRIGERATOR DATE OF PURCHASE 7-7-07 DELIVERED 7-13-07 ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER TWO MONTH WAIT. NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE. REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
Below is the service manual And the explanation for your error.
Thank You for using our site.
Huuum
Please remember to leave a solved rating.
Error Detection Category
ERROR CODE : IF
Abnormality of
BLDC FAN Motor
for Ice Making
Error Generation Factors
It is caused when F/B
signal isn’t over 115
seconds during BLDC
FAN motor operating
Remark
Poor BLDC Motor
connection, DRIVE IC, and
TR
Resource reference located here:
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Huuum
Anonymous
  • 88 Answers
  • Posted on Jan 12, 2009
SOURCE: Faulty ice maker
Hello. Yes, that is the correct position for the icemaker feeler arm. The updated icemaker has a longer feeler arm that hangs down a little more (thereby shutting off sooner when the ice piles up not so high).
Your water leak onto your food is from water spilling out of the front left corner of the ice tray during fill. This has also been updated with a plastic lip that keeps the water from sloshing out when filling up.
The photo shows that your ice tray appears to be unlevel and drooping in the front left corner. This happens with flex tray icemakers over time. The icetray does not fully flex back to its level posiiton. I do not feel you need to replace the entire icemaker. Repalcing just the ice tray should fix your issue.
Hope this helps, please rate my solution.
Anonymous
  • Posted on Mar 22, 2009
SOURCE: LG refrigerator model lfx25950tt ice maker not working
I had the same problem and replacing the filter solved the problem for me.
2answers
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
LG LSC26905 makes ice, but will not dispense through door. Ice backs up on inside of freezer door when attempting to dispense ice (crushed and whole cubes). Water dispenses OK. Any help? Thanks.
Sounds like the flap or door directly above where the cup would be is not opening. Press lever and look up in there, if that is the case there is a problem inside the door.
Water dispenser and ice wont come out
if it makes ice but will not dispence the look at the electronic p c board as it's prob bad ...
My ice maker has stopped working. It appears to go through its cycle with the ice tray flipping over--no cubes!! The water has stopped filling the tray. The water supply looks good and water is still...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
1helpful
Lights out and water and ice dispenser not working
You have a bad main board. To replace the board remove the cover on the back to access the board. Be carefull when removing the plugs.
The place where the water filter plugs into the fridge has sprung a leak. Have not been able to use the water or ice maker.
You should be able to remove the filter and insert in its place the plug that came with the fridge. It should then run without the filter. Odds are the o-ring on the filter is nicked, or the filter is not properly inserted. It is a little tricky - if you still have the owner's manual that should clarify how the filter is inserted.
1helpful
2answers
How do you unlock a keypad on an lg refridgerator?
I assume that you means the keypad that controls the different modes for the water/ice dispenser. Press the far right key
3helpful
Ice maker panel came loose on LG LSC26905TT fridge
Please use the attched link to get the service and user manuals for your fridge. There are exploded views there as well so that should provide you suffiicient information to reinstall your panel. You can also get part numbers etc for replacements if that is necessary.. Hope this helps you...
http://136.166.4.200/contents/Fridge/LSC26905.htm
Regards,
Rick
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
