MY SCREEN IS BLANK - RED KEY AT BOTTOM LEFT SIDE OF SCREEN - HOW DOI UNLOCK IT PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!! screen lock, blue screen red key in lower left hand corner
Hope that helps..........
Please try this:
On the remote hold down the (F) function key and press mute.
Let me know when it is FIXED!
Your screen is locked, so you must unlock it by using the remote!
Thank you Brian, I have a guesthouse, and 1 of the guests locked the tv I did as you said, and it worked THANK YOU SO MUCH!!!
Try this manual;
[PDF]
AT M C T
Try pressing the ( F ) button and the mute button at the
same time on your remote control.
Here's the link for the 2402s manual:
http://www.retrevo.com/search/v2/jsp/dow...
Pass Code Menu
This menu allows you to change the access code for the Parental Guide
functions of the TV set. Pressing the Menu key when Pass Code
Control is highlighted. This will turn on or off the Pass Code function. With
the Pass Code function ON, you can also change the Pass Code. Use
the down arrow key to highlight Pass Code, then enter the new Pass
Code using the numeric keypad. Press the left arrow key when finished.
1. The factory default pass code of 6688 is also the override code, in case
you forget your new pass code.
2. The factory defaults have TV-MA and MPAA-X ratings blocked
1 try using the right and left arrow keys
or press the menu key
then when it ask enter the code 6688
or
pree and hold the function key
then press mute
release function key
hey any luck?
1. To use the override code:
2. Hit the MENU key to get to the menus.
3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK.
