Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
Posted on Jan 31, 2011
We have a Bosch Nexxt 100 Series Washer. The door lock is stuck and will not unlock. We have a load of clothes in the washer but are unable to get the door to unlock. I have tried unplugging the unit, rerunning it through the wash cycle, but it just won't get into a state where the door unlocks. I have tried the spin cycle, the drain cycle and still the door remains locked. Any suggestions for getting the door to open ???
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2470
Points
8
Getting the door open is the easy part. Finding out why it won't open might take a little doing -- though replacing the door latch is also easy. To get the door open, Take an awl or something pointy and place it in the hole on the small round cover in the lower left front of the machine. Now use this to turn the cover, unscrewing it from the machine. Once the cover is off, you should see a plastic rod hanging down. Pull this rod and it will unlock the door. You can now remove your wet clothes from the machine and investigate the cause of the problem.
1 Related Answer
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Mar 15, 2010
SOURCE: bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Wet clothes are locked in machine and it won't spin or drain.
open the drain plug, let the water drain and the door will open.
Light stuck on lock and wash
CHELL TRY TO DO A WASH WITH OUT CLOTHES,AND DO A SHORT PROGRAMM.
Manual release on door lock of a bosch nexxt series 100 washer
Try pulling door up before out. My washer does this when the rubber around the door gets a piece of wet paper under it, or I have overloaded it and the rubber gets moved. Once open, run your fingers around the rubber seal to verify nothing under it and that it lays smooth.
Bosch nexxt series 100 washer. washer willnot start three beeps and all the lights are on.
Welcome to FixYa.
It sounds like a bad door latch/lock. It will require you to remove the front door seal spring to gain access to the part.
If this sounds like something you can repair I'll try and help in whatever manner I can or you may opt to call a pro.
Let me know how it goes and if you require further assistance. Thanks for choosing FixYa. Good luck
Regards,
Macmarkus :)
Hello - we have a Bosch Nexxt 100 Series Washer. The front loader door is locked and I cannot get it to unlock. We have a load of clothes in the washer. I have tried to run the "spin" cycle...
Easy to do....But may need a service call from a pro to fix the underlying issue.
Take the bottom right little door off and try not to cut yourself reaching in..(OH TURN OF THE POWER). reaching in after looking with a flashlight try to grap the zip tie looking plastic hanging there and pull it down gently and it will unlock.
Of course make sure you tried to unplug it first for 10 minutes and then try turning it on again in spin mode.
Thanks,
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
3helpful
My Bosch washing machine door will not open and it keeps flashing " check door" however there is no child lock on and also no clothes stuck in door. Also I have detergent and bleach in the tray and do...
Check out this link to the Bosch service manual for more information regarding your machine: http://www.bshextranet.com/files/techtoolbox/WFMC1001UC_9000151579.pdf
This may offer some help...if this is of no use then us the associated info to contact the mfg directly for more info. Thanks, Randy
5helpful
Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
1helpful
3answers
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
