LG 37LC7D 37 in. LCD HDTV Logo
Posted on Jan 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG 37LC7D 37 in. HDTV LCD TV My screen seem to over heat, Goes blank, but TV is still on. then comes back on for a few seconds, then again blacks out
Richard Roth
Level 3:
Top Expert:
  • LG Master 9,472 Answers
  • Posted on Jan 31, 2011
Richard Roth
LG Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628883
Points
28464
It sounds like a problem in the high voltage circuit. Had a similar TV set which had the same problem. When there's power leaking from the high voltage circuit, these TV's will tend to cycle on and off. Voltage leaks are mostly caused by accumulated dust for the most part.
Loud cracking and zapping coming from tv,sounded like speakers,when it was first turned on.Was happening intermittently but now nothing.Checked power and fuse inside and nothing seems burnt or cracked
Something has blown.. possibly a resistor, diode or ??? on one or more of the boards. You should take the TV to a service Agent who should be able to resolve the problem.
2answers
I have a LG 37LC46 lcd tv. Power is going through the set but no picture. Just error message "not programmed" and then blank screen. Happened very suddenly please can you help?
When the screen goes blank, dim the lights in the room. Take a bright flashlight and shine it on the panel. If you see a faint picture, you have a backlight failure
3helpful
LG 37LC7D HDTV just went blank. Screen blacked out and green light is on but no response to input change, remote, volume, or channel change. I've unplugged it for several minutes in an effort to reboot...
My lg 37lc7d is having the same problem. My backlight is on but no display. Also the standby light blinks several times then the screen goes on but it's just all black. No a/v
1helpful
Truble switching on tv
its repair immediatly its a power supply problem,
3helpful
Frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
37" lg television
sounds like u have a dead solder joint or loose connector. poor workmanship LG (formerly known as GOLDSTAR is known for)
LG LCD 37'' standby problem
if you want i will buy the tv from you
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
