Expert
- Posted on Sep 05, 2011
Re: How to change a bulb in the Kenmore refrigerator
Most likely, you never notice the light bulb in your freezer or refrigerator until it is not working. Then it is time to replace the bulb. This is especially important with freezers, which are often in areas with poorer lighting, like basements or garages. Fortunately, the task is a simple one.
Instructions
1 Unplug the freezer to prevent an accidental shock when you remove the light bulb.
2 Open the door of the freezer, look at the top inside edge of the freezer, below the door seal and back about 1 to 2 inches from the edge. You will see a small plastic or metal panel that protects the bulb from damage and shields your eyes from the direct light of the bulb when the door is opened. Reach behind the guard and remove the bulb by twisting it to the left.
3 Put your new bulb in by inserting it into the socket and twisting it to the right to screw it in. Be sure you use a freezer bulb--it is built a little tougher and is the correct wattage. You can find them at appliance or hardware stores. Plug the freezer back in to test operation of the bulb.
Have a nice day! : ))
