GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
A
Anonymous Posted on Oct 04, 2017
I have a GE profile refrigerator that is 5 years old. The top half of the freezer is intermittently warmer -40 degrees- than the bottom causing the ice in ice maker to melt while the bottom is about 0 degrees. The rest of the refrigerator works normally. The refrigerator technician can't find a solution. He replaced the ice maker but it did not help.
mcontract794
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Oct 05, 2017
mcontract794
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
Helped
937
Points
20
Clean vacuum rear of fridge check to see if fan is spinning freely
5 Related Answers
Anonymous
  • 639 Answers
  • Posted on Aug 26, 2008
SOURCE: GE Profile Artica won't drop temp past 52 degrees
Dear FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
YOU NEED SERVICE FOR THIS PROBLEM!! SORRY!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS.PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OUT!
Anonymous
  • 13 Answers
  • Posted on Jan 04, 2009
SOURCE: GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
Anonymous
  • 531 Answers
  • Posted on Mar 31, 2009
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Anonymous
  • 1606 Answers
  • Posted on Sep 06, 2009
SOURCE: Ge Profile fridge
Pull the refrig out from the wall , and remove the rear panel . Touch the compressor and feel if its hot or running . If the compressor is cool , then the main control board is bad ( since the compressor isn't running ) . If you can solder , you can repair the board (another paragraph ) . If the compressor is warm , then you could have a thermistor or 2 bad . This would have to be checked by a technician , unless you know how to get into the diagnostics procedure . Also , see if the compressor cooling fan is working and the black squirl cage is clean of dust .
Testimonial: "Quick, professional response."
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Sep 13, 2009
SOURCE: ge profile bottom mount and temperature control
Since it's less than a year old it should have a pretty good service warranty. A relay or confusion on the mother board is most likely the problem. I could send information to put it into self diagnostics but I think you may come out better by calling your nearest GE authorized service center. If you hear the compressor clicking and or no movement of air below the unit unplug it just to prevent any further damage.Your refrigerator is too new for me to tell you how to work on it is what I am trying to say, Thanks Sea Breeze
GE Profile Side-by-Side Refrigerator - Freezer Warms Up - Motor Gets Loud - Eventually Cools Back Down
Sounds like your thermostat is faulty this should be covered by a warranty This problem eats electricity so will need attention asap
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Bottom freezer door left slightly ajar for approx. 24 hours on a GE Profile fridge. Now, freezer and fridge are at 28 and 54 degrees respectively and will not return to normal. What are possible...
Hi do you notice any frost in the back of the freezer? If you do not this is a bad motherboard, I would recommend calling GE directly if under 5 years old they will fix at an extremely discounted price if it over 5 then the board costs about $175.00-200.00 to buy.
Sean
The GE Profile PDS22sfsarss is now 4 1/2 years old. One year ago, the temperature panel stopped working and a repair person told me to just order that circuit -- which I did and replaced it myself....
Not certain this will help your situation, but here is what I did to mine.
GE Profile Bottom-Freezer Refrigerator with Electronic controls with digital temperature readout (Should include Models PDS20MFS, PDS20SFS, PDS22MFS, PDS22SFS, PDS22MFS) May also apply to other models.
Diagnosis: Search of Internet yielded no definitive fix. It appeared to me that the some minor frost buildup might be symptomatic of unseen frost elsewhere. The electronic controls could possibly be messed up.
Fix: Not knowing whether it was frost or the electronic controls (or both), did the following:
1. Turned off the refrigerator. (It is not clear how to do that. Download the owner's manual for your model from the Internet. If it is like mine, the freezer and refrigerator APPEAR to have separate controls. In fact they are linked. To turn both freezer and refrigerator off, press the WARMER button on EITHER the refrigerator OR freezer until the display shows OFF for both the freezer and refrigerator.)
2. Unplugged the unit. Let it set for 18 hours with both doors open.
3. Plugged it in (which probably reset the electronic controls.)
4. Turned it on. To do so, I followed the instructions that said to press the COLDER button on either the refrigerator or freezer. Press the same COLDER button a second time and it should go to the factory presets of 0 degrees for the freezer and 37 degrees for the refrigerator.
5. Allowed the temperatures to stabilize for a week, after which temperature adjustments can be made.
Freezer temperature fluctuating way up and down. 0 recommended. 11 degrees right now. 18 earlier. Food defrosting. Ice cream soft. GE Profile bottom drawer freezer. Only 3-4 years old.
Your problem could stem from an issue with the defrost timer, the compressor or its attachments (e.g.: relay, capacitor, etc.), or the freezer/evaporator fan motor. Contact an appliance service company.
45 degree ref and -5 freezer...unplugged.... just vac back and bottom...dust out of unit...only 2.25 years old
check the damper door between the freezer and refrige to make sure it isnt iced up and staying shut
Weekly my top freezer warms to about 40 then returns to 0 About once a week the freezer on my GE Profile Arctica PTS25LHP top freezer refrigerator warms to about 40 degrees or so then cools back down to...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
heatman101
Top Refrigerators Experts
vince
Johnny 1000
