Hi, what your toshiba laptop model and asus laptop model? You can use the asus ac adapter on your toshiba laptop only if the folllowing three conditions are met:
1) Output Voltage is within +/- 5% of your old charger's output.
For example, if your old charger provides 19V, then you can use a charger that provides 20.5V or 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, if your original adapter provides 3.42
Amps, then you can use a charger that provides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
For the specifications of the two adapters, you may check it here:
http://www.chargerbuy.com, then decide if it will work or not.
