A kind of memory card for some products as mobile, camera and so on, there are size kinds of SD card. Generally cameras using larger ones and mobile using smaller ones.
Well, I met this kind of problem before. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted to learn the solutions or causes. Best regards.
after inserting a memory card kindly restart your phone. make sure that your mobile willl support the memory cart tat you use. if so try it by restarting your mobile. if still same problem in memory card means try your memory card in other phones. if memory card works in other phone means there is some software problems in your phone. kindly ask your service men. if memory card is not working in other phone means then there must be fault in your memory card..kindly try it
hello,kindly locate your memory card data,what ever message you need to get from there,kindly click on the options key to see if there is anyway to move or copy it from there to your phone memory so that you can make use of it.
hi your phone is compatable with on certain kinds of memory cards and will not work with every other card available in the market. Kindly check your phones user manual and see what kind of card is compatiable with your phone. If even this doesnt work then i think your phones memory slot isnt working and u need to get it checked with an authorised dealer
go to www.crucial.com and run the memory utility. It will let you know what kind of memory you need and the maximum memory your computer will hold along with how many slots
Windows XP needs at least 1GB to run acceptable. What kind of memory you need to buy depends on your motherboard. Read the motherboard's manual or bring your computer to a computer shop to identify the memory.
