RCA F32665 32" TV Logo
Posted on Jul 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NO SOUND The TV was working earlier in the day, and now there is no sound!!! When we turn up the volume, the sound clicks as the volume rises but thats all. We have Direct TV hooked up to the TV. The TV is about 8-9 years old and this is the first problem we've had with it. I was watching tv when the sound went off. You can hear a clicking sound when you turn volume up and down. I am cable connected, and also have dvd. I still have sound when I play my dvd, but no sound when just the tv is on. The tv is not muted. The speakers are on, because I checked the audio output and speakers control panel in the audio menu. This is the first problem I've had with it.
  • 2 more comments
  • sandrajok Jul 19, 2008
    I tried the solution, unplug and replug tv, it didn't work.
  • Telewriter Jul 20, 2008
    I had the same problem, just started today, only on one receiver - the others are fine. Plugging and unplugging didn't work, reset didn't work. Is this a Direct TV problem then? Kind of odd I'm not the only one whose sound just quit TODAY!
  • Anonymous Nov 03, 2008
    My 32 RCA was on and a watching a program on Direct tv and I could hear a click sound and the sound went off and just made a clicking sounding with trying to change volume. Well after reading suggestions here to correct the problem I turned power off to the tv a few minutes and now I have volume. Thanks alot to persons who gave that advice but why do you think this happened.
  • Anonymous Nov 24, 2008
    I tried the solution and it did not work. There is no sound output looking for owners manual for model F32665.Frank Gilbert, AZ
Anonymous
Level 2:
  • Expert 71 Answers
  • Posted on Jul 19, 2008
Anonymous
Expert
Level 2:
Answers
71
Questions
Helped
20464
Points
105
Unplug the power to the tv for couple of minutes; replug and should have sound!
  • Jack Edwards
    Jack Edwards Nov 23, 2013
    didnt work and how many minutes would u say is a couple
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 27, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
430
Points
Tried the unplug and it did not work
Anonymous
Level 1:
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
430
Points
I just had the same problem. I unplugged the dish box for 1 min plugged it back in and wala!, the sound come back after finding the signal.
1helpful
2answers
I set the volume to 40. After a little while the volume starts dropping down. If you do not turn the volume back up the volume will eventually go to zero all by it self and turn off the system.
HDMI Audio drop out? - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > HDTV Forum
Sep 21, 2005 - My Panasonic TH-37PX50U plasma has an audio drop out problemwhen .... The drop out occurs on both TV sound and receiver sound. ... very littlebass effects when playing DVD's through the HDMI cable when I compare it to ....Most noticeable when I turn down the volume control on the set top box (and ...
Dynamic volume problem : Ask Audyssey
https://audyssey.zendesk.com/.../20013893-Dynamic-volume-problem
Apr 8, 2011 - it appens only when dynamic volume is ON (day, evening or midnight) . the audio signal of the TV is on a optical Toslink cable and it ... and so it drops thevolume to make sure the sound will not be too loud. ... April 11, 2011, 12:40 AM .... Setthe audio setting on the receiver to Stereo vice Surround Sound.
How do I stop my surround sound system cutting out? - TV DVD HDMI ...
ask.metafilter.com/.../How-do-I-stop-my-surround-sound-system-cutting...
Jan 21, 2009 - When the volume is at higher levels, all but the center speaker cuts out..... That is why I just turn down the TV's speakers to 0 and listen to things from thereceiver. ... notice that the sound is coming 40ms later or earlier than the video). ...system), and adjust the A-V delay on the receiver until the audio lag is ...
How do I turn up volume on HP computer?
If I understand correctly, you had a tech assisting you earlier and he turned off the sound and now you want to turn it back on - is that right?
Check in the lower right corner of your monitor for the speaker icon. If you see a red circle with a line over the speaker it means the tech just muted the sound. Click on the Speaker icon and open the volume control - you will be see the Mute option and just click on it.
If it is more, and I misunderstood your initial description, please respond with the model of your computer, the operating system and what the tech was called in for in the first place.
Regards,
Matt Burns
Sound not working, Was working earlier today and after shutting off the tv, when we turned it back on, sound wasen't working
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
8helpful
3answers
No sound at all. running windows xp After updates in windows updater a couple days ago I have been experiencing no sound through my laptop speakers.
if it happened after you updated your windows than restore your computer to an earlier time and that will resolve the problem.
if not than,
Click on start >> go to control panel >> double click on system >> click on hardware tab >> click on device manager >> right click on sound drivers and click uninstall >> then click on scan for hardware changes and than check if it works.
The volume does not work at all. Earlier in the day it was fine.
try unplugging from wall. wait 2 minutes...... plug back in. if still same problem, i ask do you you have a cable bax or dish box? unplug them also. when plugging every thing back..... you will have sound. enjoy!
2answers
Volume not working
You have lost your audio driver. Go to manufacturers web site, help and support center, and download the new driver. That should fix your problem
2helpful
No picture, no sound, no lights, faint clicking sound, fuse ok
HT transistor, or rectfying diode from chopper transformer is blown.
The sound has quite working
First, NEVER turn the volume all the way up to see what's wrong. If HALF volume doesn't work you're only risking a catastrophic speaker blowout if you should suddenly flick the switch that's causing the problem with FULL volume on.
Look for the MUTE or Volume +/- controls on the remote and indicators.
44helpful
3answers
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first
No av-input picture with sound
Goto the site www.TvRepairKits.com and get their "chirping" TV repair kit. It will fix the problem of the dead set with high pitch sound or chirping sound.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
