SOURCE: Luminox watch band (metal) size smaller
Thanks guest, that worked for me - just used a thin awl and pushed in the direction of the arrows. Now its snug as a bug!
SOURCE: remove the extra links in a luminox 3204 watch band
It was nothing more than split pins holding the links together. I pushed them out removed the links and pushed them back in.
SOURCE: replace rubber watch band
if it a spring bar you can compress the bar with a small pen knife and it should then pop out. if this helps please rate joe
SOURCE: How to replace the rubber wristband of a luminox watch
If you have a new wristband, there is a spring loaded lug where the band joins the watch, use a sharp knife or jeweler's screwdriver to slide the lug from the watch
SOURCE: Missing piece to Luminox 3000 black rubber watch band`
Try parsecent.com they can get the part or a substitute part, the keeper is not sold separately tho, you would have to buy a complete band...good luck :)
