Here https://www.amazon.co.uk/Franke-Kitchen-Drainer-Stainless-112-0050-236/dp/B00XVYTU12 you can get the Franke inside sink dish drainer but honestly speaking, it's good a right option and I would recommend you to go with over the sink dish drainer like this https://www.amazon.com/gp/product/B07RQMPY7Y. Over the sink, ones are very reliable especially when you do dishwashing manually. However, choices are all yours.
SOURCE: I need a new franke
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
SOURCE: I have a brown colored stain in the bottom of my
I used Cerama Bryte for the dark colored stain, I left it on for about 5 minutes and then rubbed it clean, the stain is gone. Now I tried it on the small aluminum scratch marks, no thank you, it couldn't help that problem. Still seeking a solution. Thanks
SOURCE: Insulation falling off bottom of sink
This insulation is important as a sound reducer so I would definitely glue it back into place. Go to any home depot, lowes, or other hardware store and get construction adhesive, the tacky kind will work best for your purpose. Then just put a thin coat directly on the bottom of the sink and stick your rubber back in place.
SOURCE: Franke overflow waste connection
Once that fitting is damaged it is very difficult to repair. Try contacting Franke for nearest distributer and see if they will replace.
