Question about Amana ARB190RCB Bottom Freezer Refrigerator
MY FRIDGE SEEMS TO FREEZE FOODS NO MATTER WHAT SHELF OR DRAWER THE FOOD IS IN
    New Friend:
  • 20 Answers
Put the duals back to factory setting. Always the middle number and it is always highlighted. If they already are then turn the fridge only down a setting. The freezer always stays at factory I think 3 or 4 on Amanas.
Posted on Jan 28, 2011
6ya staff
SOURCE:
GE Profile Brita Fridge. Have setting down as low as possible and crisper foods continue to freeze. How can I fix that?
You need an internal digital thermometer to see if 1 is the coldest or the hottest. If you turn it to 6 and the temperature remains the same, the thermostat is faulty.
If 1 is the warmest and it continues to freeze crisper foods like lettuce, you need a new thermostat. Your ideal temperature is between 3 and 4' Centigrade at the coldest part, usually above the bottom shelf.
Aug 23, 2016 | GE Refrigerators
My freezer only freezes certain food. All the
Get a freezer thermometer and ensure the temp is turned down to between 0 and 10 degrees F.
Oct 05, 2014 | Refrigerators
What's a Kitchen Organizer?
A kitchen organizer is any kind of closet, shelf or drawer in the kitchen, and sometimes in the fridge, that help organizing and putting in order tools, food and utensils. It is especially useful in full kitchens, both big and small, where there is a need to separate a lot of tools and organize foods, pots, pans and ingredients that otherwise would be hard to find, or would be very chaotic.
Oct 20, 2013 | Home
How long can I keep freeze-dried foods on the shelf before they go bad?
You should always double check with the manufacturer, but most companies boast a shelf life of 25-30 years.
Jul 31, 2012 | Camping, Backpacking & Hiking
Can i freeze food in a matsui mini fridge freezer with ice compartment?
You can do so but the freezing temperature may not be as good on a standard fridge specially for frozen foods as the mini is mainly meant for emergency foods and beverages.
Sep 25, 2010 | Refrigerators
I have a side by side Fridge. Model TPX24PRBBWW
turn the controls to factory settings and give it a couple of days, if it is too cold the ice can not release!!
Nov 15, 2009 | Refrigerators
I can not change temperature to more than 41f. Lower temperatures are OK
Temperature is perhaps the most critical means of control in the prevention of foodborne illness. Harmful (disease-causing) microorganisms grow within a temperature range of 41 F to 140 F (referred to as the "Temperature Danger Zone"). Many foods, especially raw animal products, naturally contain harmful microorganisms. Keeping foods out of the Temperature Danger Zone prevents disease-causing microorganisms from growing in foods. Proper cooking and reheating of food is important because heat destroys disease-causing microorganisms that may be present. Ensuring proper heating and storage temperatures is essential for assuring safe food in retail operations. Temperature guidelines differ depending on the type of food and method of heating method.
Freezing
Most pathogenic microorganisms will not grow below 41 F, or their growth will be very slow. However, many spoilage microorganisms (which cause foods to taste and smell bad) can grow at temperatures well below 41 F. Most foods that are frozen in food retail are done to improve quality and increase the shelf- life of the product. Most foods will freeze at about 28-30 F. To ensure safe freezer temperatures, be sure that your freezer is maintained at least 28-30 F or below (foods should be frozen solid). Ideally, foods should be frozen at 0 F or below to maintain quality.
It seems that your Refrigrator's higgest point is set to 41 F
Jun 19, 2009 | Refrigerators
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Amana ARB190RCB Bottom Freezer Refrigerator Logo
145 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
