In order to have the Sleep Sheep run without a timer, you have to set the switch in the middle (left is 23 minutes, right is 45 minutes).
When you set it to the middle, what happens? Does it not turn on at all? Does it run for 23 minutes? Does it run for 45 minutes?
23 minutes.
Are you sure you have it set squarely in the middle? If so and it still turns off after 23 minutes, the internal switch is bad. If you are handy (or know someone who is!) you can take the sound box apart and adjust the contacts on the switch, otherwise the easiest solution is to replace the Sleep Sheep, since Cloud B doesn't sell replacement sound boxes by themselves.
I did set it to the middle and it didn't work.
