Water valve and hose screens may be clogged letting very little water in and therefore taking a long time to fill.
SOURCE: LG WM2077CW (UE error code)
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
.....& rate me if helped.
SOURCE: cycle takes forever
IE is Inlet Error. Turn off the water valves behind the washer and remove the hoses from the machine end. Look inside the spot the hoses were attached to, and use a plier to pull out the screen and clean it out. (probably only need to do the cold side) Re-instert screen(s), re-attach hoses, and turn valves back on. (Also, make sure hoses are not kinked behind machine.) Times displayed are estimates, and vary due to water fill rates, and load type and size. In your case, the water fill rate is the problem.
SOURCE: When I run a load in my LG WM3431HW, it is
check the outlet pipe & any filters.the may be a small sock blocking air outlet.
SOURCE: I just bought this washing machine a week
The newer washers are much more gentle on your clothing, but they also take their time to do the job...
Yes, it can be a pain to have it take so long but your clothing will love you for it and will stay nice for you longer...you will also be using less water...
Not much you can do about it as the engineers that know all are the ones that program these things...
heatman101
