All lights function on my machine but when I close the door and push start, NOTHING. All the lights work when selected. Thinnkk it is the door latch mechanism. Have tried unplugging, plugging in to set but no change. How do I open the machine to replace the latch. Hear it is easy but hav enot seen directions. Please help. I have tried 5 repair companies and between 1 week waits and telling me it sound like the computer needs replacing ( yea, right..) I may just have to do this myself. Have replaced a drum belt in an old dryer before..... HELP
SOURCE: Kenmore Elite 10.4708 front load washer won't start with new load
Uh oh! It did it again! This time I had to unplug 6 times for one cycle. Seems to be on the last 2 minutes most of the time. Today my husband is taking the control unit and looking for soldering problems. On Askmehelpdesk.com this man told of taking the bottom panel off and there is a little black latch thingy you pull to open the door lock manually. Also he said that the K2 and K4 relays are usually the problem if it isn't a soldering issue on the connectors. ( On the CCU);. He said one of them is usually burned and to clean it off and then switch it with the other one which carries less voltage, therefore doesn't burn. You can use a pencil eraser to do this. My husband told me they did this in the Army for MOose code contacts. He just told lme the soldeirng looks good on the connectors and is now working on the K2 and K4 relays. If you go to Askmehelpdesk.com/appliances you will see these tips are for the Whirlpool Duet whic is apparently the same machine as our Sears Kenmore H4's. Gosh, I hope this helps someone as it sure is not fun trying to track this problem down. I am glad you got Sears to come out. I will NEVER and I repeat NEVER buy from Sears again! Did I mention I wrote a letter months ago when I was having a hard time getting warranty work done.( Which I never did) that I had written to the pPesident, CFO and the Texas Attorney General for Consulmer Protection Division and never got a response from anyone?
SOURCE: Kenmore Elite Front Load washer with dl F error code.
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened.
You're gonna rate me..............?
SOURCE: Kenmore front load clothes washer.
it sounds like the door sensor is not aknowledging the door is closed.
SOURCE: Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
SOURCE: Kenmore Elite problem
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^@#
