Is this a propane or natural gas furnace ?
Check the condensate drain lines in the furnace. disconnect the power and remove the cover. Remove the black drain lines and flush and clean with a water and clorox solution. Then check the rest of your condensate drain line for blockage. the blockage is freezing and causing the furnace to shut down for a pressure problem.
