Washing Machines Logo
Posted on Jan 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The circuit board on my 9 year old neptune washer went up in smoke. Do I replace the circuit board or by a new washer? Thank you!
Hans Pearson
Level 3:
  • Master 2,510 Answers
  • Posted on Jan 25, 2011
Hans Pearson
Master
Level 3:
Answers
2510
Questions
0
Helped
769941
Points
7758
Check the price of a new circuit board against the price of a new machine. Take into consideration that installing a new circuit board yourself might see the new one go the way of its predecessor due to some other fault. Have a qualified technician give you a quote on the repair and again compare prices.
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
1helpful
3answers
Smoke when running.....smells like rubber....washer is top load.....about 13 years old....model LAT8426AAE...HD 2 speed....9 cycle. Belt shot?
Its possible. This one has two, located underneath. Lean the machine back to check them. Make sure all pulleys turn freely before replacing them
1helpful
My bearings went out out on our neptune. The
It is a complete tear down to replace the main tub bearing. The bearing comes pressed in the rear shell, oversized shipping on part. If the inner basket spindle is froze or badly pitted or groved it is another expensive part, The repair is about two or three hours depending on how easy things come apart and how much working room there is if it is done in your house. So yes it is expensive to repair, and not a easy decision,
good luck
Neptune mah4000aww spin cycle
BELT IS LOOSING TENSION CAUSING IT TO SMOKE REPLACE BELT
3answers
WON'T SPIN OUT. 4 SERVICE CALLS SO FAR
If you remove the motor control board, you will probably see burnt spot on the board.Board and motor need to be replaced, pretty expensive repair.
1helpful
Strong electrical smell with smoke coming out
Check the lower motor control board. See www.neptunehelp.com for disassembly pictures. It is possible you will need to replace the motor control board and motor if you have the original one as Maytag has redesigned these two components due to reliability issues. The new motor conversion kit is part # 12002039.
If there are any burnt components on this board then it will have to be replaced. There is also a 10 amp fusesoldered to the board. if this fuse blows the tub will not move anymore and the motor control board / motor will have to be replaced.
Have you noticed your Neptune's spin cycle getting loud? If so, the seal kit and bearings need to be replaced. See www.neptunebearing.com for more info on the special bearing tool kit you can rent that includes use of a DVD that shows you how to disassemble Neptune, replace bearings and install the seal kit.
Water won't drain won't spin Kenmore front loader
glad i could help.if you have a chance ,i thank you for you great rating
1helpful
Machine starts beeping for no reason on my maytag neptune tl. It keeps flashing OP. I even the clothes but still beeps. I can only use super wash and color setting. Also all the left side button mode...
I don't know if your machine is the Neptune series. If it is, there is a culprit called the wax motor in the door switch assembly that shorts out and fries the r11 resistor on the control circuit board. This could cast as much as $250 to replace the wax motor and control circuit board. It may be better to look for a new machine if it is many years old. If not, you may be able to justify such expensive repairs.
Rinse cycle nonexistant!!! HELP!!!
Yes the wax motor does need tobe changed at the same time.If you see the burnt spot, your control board has got to be replaced (Maytag insists that the door latch wax motor is partly to blame ,so they've modified it and in the last 6 years there have only been a few Neptunes that this problem re occurred after changing these 2 parts
.Please rate this !!!
Maytag neptune washer
yes, but 900 is a little high for my area. is it loud in spin now? the seal can be replaced for about 50-80 part labor is 1 to 3 hours. if you just smelled the smoke and it is not loud you are ok for a long time, reduce load size and it will probly be ok for some time
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
