Timex Sports Ironman Triathlon 50-Lap 59231 Wristwatch Logo
Posted on Jan 12, 2018
I bought the woman's ironman and I can't hear the alarms at all! They are way too soft and if I'm out for a run and want to set time for intervals....forget it, I can't hear a thing. Am now pinning the damned thing to my shirt up as close as I can to my ear. Does anyone know if this can be adjusted?
5 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 04, 2009
SOURCE: Need to shorten the band on a Timex Ironman Triathlon
These pins will definetely come out- poke a bit harder. You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 09, 2009
SOURCE: timex ironman triathlon - need directions to adjust time for day
Follow this link and download usars manual for your watch:
http://assets.timex.com/manuals/?timexBrand=core
Use ZOOM tool as the writings are tiny.
Do not forget to rate, please.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 25, 2010
SOURCE: how do i set the time/alarm etc on my 8 lap timex
Get manual in My tips and tricks.
Anonymous
  • 2501 Answers
  • Posted on Feb 21, 2010
SOURCE: Alarm is not loud enough to hear,
There should be a battery low indicator on your watch (I think).
If you haven't got instructions for your watch you can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
There should be mention of a battery monitor if there is one.
Anonymous
  • 2501 Answers
  • Posted on Apr 07, 2011
SOURCE: i recently bought a timex ironman with supposedly
You can get instructions from the Timex web site "timex.com".
manual download"
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
How do I turn up the volume on timex ironman watch alarm?
If the spring is missing, you can wind a temporary one out of extremely fine coil wire around a sewing needle . If watch case is closed and alarm does not sound try stretching the coil slightly. If alarm comes on keep stretching coil a bit further to see if alarm gets louder. Similarly, coil may be too long if alarm does not go on. Then gently squeeze coil a little smaller and put case back together again to check alarm. If it is too soft then squeeze the coil a little more.
There is definitely a sweet spot for coil length whether hand made or store bought. Lots of fiddling but it works.
1helpful
How do you set a timex ironman wathc and how do you use the stop watch and alarms
Hi hdirkse,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
manual download"
6helpful
How do i set the hourly chime on the timex ironman flix watch?
Press Mode till you are in Alarm setting
Press and hold split/start button till you hear the double beep. You should also see a small clock icon above the last digit of the seconds... you are all set. Repeat to deactivate hourly chime.
13helpful
How do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
3answers
Timex 1440 Sports Aggressor: how to set time and alarm
i just bougth a 30 lap shock/resistant timex ironman triathlon, and i need to know how to use it... i have no instructions thanks
1helpful
Old model timex compact disc digital audio
Hi catlady05,
Setting an Alarm
Hope it helps.
Watch isn't recognised by computer
Hi Hoffman518,
To set the alarm on your Timex Ironman, please follow the steps below.
Hope it helps.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
