Question about JVC Televison & Video
JVC HD56G647 TV was working fine. Made a popping noise and now we have no picture or sound. Both lights on the front are flashing in unison. Help!
  • JVC Master
  • 1,257 Answers
The popping noise is not a good sign. You definitely have a shorted horizontal IC and probably a bad flyback transformer. You will find several bad capacitors that contributed to this problem. The cost of repair will be more than your depreciated TV is worth. Sorry..look for a new one. Thanks for asking and show a few hands of support!
Posted on Jan 24, 2011
Just changed build yesterday. Today tv has a dark shadow in the upper left corner. Reset tv. Checked inside for any blockage. Nothing noticeably wrong.
Posted on Jun 07, 2013
  • matt martin
    matt martin Jul 18, 2013
    Is this TV a newer flat screen or the old big and heavy tube type TV?
6ya staff
SOURCE:
Our jvc tv made a popping sound and now has no picture. It also buzzes 3 times and the red and blue lights flash fast on front.
Something went bye bye. Check out your power supply for bad, burned components and/or blown caps - the latter often explode in their death throes.
Nov 03, 2015 | JVC HD-52FA97 HDTV
Where are the fans on a jvc hd56g647 projection TV located
The problem you are describing doe not seem fan related. I would recommend a servicer to inspect your TV internally
Jul 23, 2014 | JVC HD56G647
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
TV was on and had a picture, and then nothing w/flashing power
Your lamp has blown. Time to get a new one.
the hyperlink button doesn't seem to be working, but just copy and paste this link into your browser. It is linked directly to your tv's replacement bulb.
http://www.discount-merchant.com/JVC-LCD-Projection-TV-Lamp-TS-CL110UAA-TS-CL110U-p/jvc-ts-cl110uaa-hd-56fn97.htm
Nov 11, 2009 | JVC HD-56FN97 56" Television
Need Help with tv problem
tiene que revisar la tarjeta de comvergencia
Aug 26, 2009 | JVC AV-48P575 48" Rear Projection...
Jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
Jun 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
Tv has sound but no picture
my rca hd model hd50lpw164 has no picture. some sound and a electrical popping noise.
supect the lamp is out.
where can i obtain new lamp and whats the cost.?
david
Nov 20, 2008 | RCA HD50LPW165 50" Rear Projection HDTV
TV wont power on, clicking noise and flashing standby led
Sounds pretty bad to me, I had a computer monitor that did a similar thing when plugged in after blowing, it's not a good thing. I didn't even bother to mess with it. You may have to replace the whole power board or at least have a whole handful of pieces to re-solder. It most likely isn't worth it unless your other tv's are under 30" and you don't have a lot of money ;)
- Dave
Dec 28, 2007 | JVC AV-32D305 32" TV
Televison & Video Logo
232 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
