Dryers Logo
Posted on Jan 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a power plug for my asko 7305 dryer and can not find one anywhere
Norman Worley
Level 3:
Genius:
  • Master 1,273 Answers
  • Posted on Jan 23, 2011
Norman Worley
Master
Level 3:
Genius:
Answers
1273
Questions
0
Helped
325136
Points
3473
Assuming that you need a 220V connector, they can be purchased at home Depot. They are generally made with about three feet of cable attached. you will have to take the back plate off of the dryer and attach the three leads to the proper termination.
I have a Asko 7305 dryer,can I have a regular 240volt dryer cord put on it, so I can use existing wall receptacle ?
I think you are asking if you can change the cord from 220 amp to 110 amp so you can use a 110 wall receptacle...NO you cannot not.It would also probably start a fire
May 13, 2015 • Asko Dryers
1helpful
Fuse on asko dryer 7305 blows after a few minutes on
I assume you are talking about the reset under the little rubber plug on the back of the dryer? The most common cause for this is the very fine lint filter on these Asko's getting dirty and restricting airflow. It may LOOK clean, but unfold it, scrub the screen with a soft brush and dish soap, on all 4 surfaces then let it dry before using it. If this doesn't solve the problem, unhook the dryer vent and try running the dryer with the vent hose removed from the wall. If it doesn't trip then, you need to have your house vent cleaned out because it is restricting airflow. if THAT doesn't fix it, try removing the lower panel at the bottom, then remove the fan cover (kinda round and all the way to the left behind the panel) and checking to see if the blower wheel is clogged with lint, or if it has come loose and is not spinning at all. One of these is almost certainly your problem, unless this is a condensing style dryer. If that's the case then you probably just need to pull the condenser out and clean it.
Nov 14, 2012 • Asko Dryers
1helpful
How do I change the power cord on my asko 7305 dryer?
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
1helpful
When drying a load of clothes the dryer (Asko 7305) simply quit and when I came back to the unit the clothes were dry, but the digital panel was dark and no power available to the unit. I have pushed the...
Hello Susan, Welcome to FixYa. Have you checked to see if perhaps one or both of the fuses may have blown at the back of the unit...I don't mean the hi-limit that you already referred to...I mean the in-line fuses the Asko machines are equipped with. Let me know and we can move forward from here. Regards, Macmarkus :)
1helpful
Model 7305 - power light comes on when switch is pushed but none of the cycle lights or Start button come on when buttons are pushed
Problem was solved by pushing the very hard to find black reset button in the center of the back of the dryer.
Feb 22, 2010 • Asko Dryers
2helpful
I need a rubber gasket that goes around the lint filter on an Asko 7305. It is available? If so, what is the price delivered to California. Thanks.
Go to repairclinic.com the part you need is around $15 and the shipping is good on that site I have bought alot of items from them and are great dealer .....
Nov 17, 2009 • Asko Dryers
Asko 7305 dryer keeps tripping out hi-limit on back of unit please help
make sure that the heating element is not shorted to the cabinet. Usually when you replace the hi limit you should replace the thermastate along with it. What is the brand of the dryer?
Jan 04, 2009 • Dryers
5helpful
How to change dryer belt on Asko 7305 dryer
You have to pull the back off the dryer.Then you,ll be able to see how it comes off.Ussally its on two pulleys similar to a car.There may be a tensioner on it to to keep it from slipping.If there is one you,ll have to losen it to remove the belt & replace it,then tighten the tensioner back up.Ussally you keep about a 1/4" to 1/2" free play on the belt.You use a sraight edge on the two pulleys to measure it with the belt on,tighten belt tensioner till you have the recommended tighteness.
Top Asko Dryers Experts
Mat Kramer
Mat Kramer
Level 1 Expert
Paul Carew
MattS1978
Level 1 Expert
Are you an Asko Dryer Expert? Answer questions, earn points and help others
