Listen for a clicking sound coming from the compressor. if its not running. its possible to hear a clicking sound every five minutes or so. this is the compressor trying to start, but fails..if this is whats its doing...remove cover from compressor..there may be a plastic cover fitting over compressor terminal area. remove this and remove relay. shake it and if it rattles...its bad.
now, its possible, its running but not cooling...it could be a derfost problem,meaning there is too much ice on freezer coil to make the cooling cycle work. remove cover in freezer and defrost coil with hair dryer...check for evaporator fan too, this can cause same symptom....
Hi, You may have defective compressor / motor or thermostat. Please check it out.
