Gas valve is not kicking in or gas shut offs are off. Can you check voltage where 2 wires connect to gas valve. Can you see blinking lights thru lower door window and count blinks. Code sticker should be on inside of lower door.
This furnance was just installed and worked fine for about 5 minutes and then shut down. At that pointe the furmance kicks on the glow rod lights and then the furnance shuts down after about 60 seconds it goes through the same cycle. The burners never come on
