I took my battery out because my screen froze and now i try to put it on it just has the white screen with the black square on it and just stays like that, i tryed charging it, taking the battery out/sim/memroy card everything but everytime i try start it up the white screen with the black square just stays there forever
It clearly says on the downloading screen that you must not turn off the PSP, disconnect the AC charger (if connected), or put the PSP in sleep mode. Pretty much leave it alone when you download it. To reset the PSP, you can take out the battery and put it back in and it should work again. Then re-download the update.
ur battery is dead!!! even if u have a new phone......just plug in ur phone and take out ur battery and if it still duz it that means u killed the battery.i hope this helps a little......info by MR.GIZMO
For this problem that you are encountering you may try reprogramming your mobile phone or the best way bring your phone to the nearest repair center because reprogramming the of the mobile phone is very risky
I had the same monitor and same problem. Nothing you can about it if your computer works fine... than its not your computer's falt. I got a new monitor. That's the best you can do too mate! :)
I had a similiar problem and i took the battery out and my sim card and left them out for a few hours then i tried putting them back and mine seemed fine, did you try charging it? I would give verizon or watever service you have a call and if they dont pick up bring it down, they may be able to help. I would replace it.
i do to and i cant get another fone as i cant afford to get a new one . mine occured wen i was reciving a video from bluetooth it froze then i took out the batttery then put it back in but wen i turned it on i had a white screen and also now wen i turn it on it dosnt turn on at all then only thing it eva showns wen it is on is a white screen. - bloody hell i wrote an essay
We can start with the easy stuff first. Move the memory chip to the other slot. Remove the small square plate on bottom of the laptop. You'll need a really small screw driver for this. If you have two chips, remove one and see if the laptop will boot-up.
