Kyocera FS-4000DN Laser Printer Logo
A
Anonymous Posted on Jan 19, 2011
Kyocera FS-4000DN is showing install MK; Can the problem be fix without buying a Maintence Kit for $532?
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Jan 19, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2554735
Points
31058
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
Mike
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 167 Answers
  • Posted on Apr 17, 2014
Mike
Expert
Level 2:
Cheetah:
Answers
167
Questions
Helped
43833
Points
230
You can continue to use the printer with the Install MK message showing untill one of the consumable parts fails.The consumable life is 300,000 pages and should be fitted by a technician.
shadapar
Level 1:
Habit-Forming:
New Friend:
  • Contributor 22 Answers
  • Posted on May 26, 2014
shadapar
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
22
Questions
0
Helped
32209
Points
24
You can clear the Maintenance message by scrolling down to service/Maintenance menu. I misremember which menu off the top of my head, but you should see it if you print the menu map. The 3900/4000 are keyed to total page count, not actual life of the drum unit. if the drum looks good, the developer looks good, and the fuser looks good, you can generally reset these to no ill effect. (for Kyocera, some other brands are REAL cranky about reseting mk counts.)
Fs 1035mfp reset maintenance kit message
hi
find link for solution
https://www.youtube.com/watch?v=Dco3csuDDkQ
Install MK Kit Kyocera FS-9130 How to reset MK Kit Counter
you can reset the counter but on the falcon engines if you go past the maint. cycle they will eventually fall down and print solid black copies.
Reset password?
first try the default pass word of user name:Admin pass:Admin or Admin00
Tengo un problema con la impresora kyocera fs-4000dn, que me sale el mensaje llamar servicio 7410:0052827, me gustaria saber a que se deve el problema. saludos...
tengo un Problema con mi empresora Kyocera FS-4000DN Laser Printe. me aparece comprobar caja de toner y no me deja imprimir les ruego q me colaboren muchas gracias por los servicios
1helpful
We have a Kyocera FS3830N - message install MK -
MK is the maintenance kit. You can check the Kyocera site to find out where to get a new kit and how much they are:
http://usa.kyoceramita.com/americas/jsp/Kyocera/products_printers_details.jsp?pid=12331
Most of the time the message is just displayed because the machine has reached a certain number of pages, but it should still let you use it normally.
Kyocera FS-4000DN Laser Printer call for service 7000:0103031
that's just a toner motor error..most likely the toner was not put in properly..remove the toner than reseat the toner making sure it snaps secure into place..you should than be fixed
10helpful
Install mk
install MK means replace the maintains kit . maintains kit is belongs to drum ,developer , drive gears ..... after 250000 print it asking to replace all the things ....... this is not harmful the printer it will work fine don't worry about the install mk....
47helpful
2answers
Message stating install MK
You have done more than 300,000 pages. I wouldnt waste your money on a Maint Kit, just stretch it out by doing the following.
Press Menu/Ok (Main menu)
Go into [>>Service]
Then press the right arrow.
Then find [>> Maintenance]
Press the ok key, then it will show [>> Maintenance?]
Press the ok key twice, and it will reset all the counts on your consumable components (Drum, Developer, Transfer Roller, ETC)
1helpful
Error code 0150:0008438
bad engine board... replace it...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
